GC/yellow. bottoming out.
Rep Power: 0 GC/yellow. bottoming out.
Hi !
I have a few new set of Ground control on my koni yellow ! I have a EM2 2005.
In the GC kit, the bumpstop for the front shock came in the kit. I instal all of this and I botom out in the front a lot time with only a little hole on the road.
In 2 milles, I can hit the front bumpstop 5-6 times. My car is juste dropped between 2 or 2.5 inch.. My back is more dropped and doesn't hit the bumpstop.
Do you know if extended top hat exist for macferson strut ? Does I really need to raise my car ? Because with my eibach sportline, it was pratically the same height and that never hits bumpstop with my sportline.
The front bumpstop which came in the GC kit was already cut.
Thank you for your help !
Rep Power: 0 Re: GC/yellow. bottoming out.
UP ! I search everywhere on the web and i can't fin extended top plate for macferson. I have stil 1 inch and half on my front sleeve but I can't go lower just because I hit the bumpstop !!! I need more travel.
1 Post
Rep Power: 328 Re: GC/yellow. bottoming out.
take a picture of your setup. do you have the stock top-hat on there?
i have yellows/GC and i never bottom out. and i am slammed.
sl33pyriceboi, I will post a picture saturday !! to give you an idea : I have 195/55/r15 tire and put 2 finger between the tire and fender in the front.
In the rear I put 0 finger, the rear is at the same height that the fender.
And yes I have the stock top hats !
One thing, I switch the rear spring in the front and the front spring in the rear.
Normally it's 425k for the rear spring and 375k for the front spring. Now, I have the opposite, but that change nothing of the shock bottom or not bottom out because rear spring are more hard.
Lowlife9, spring perch is the place where the spring seat ? If it's that, no I didn't cut it !
When I put the front sleeve at the more low, the bumpstop directly seat on the rubber bumstop, I have NO travel. All the chrome cylinder is enter in the koni shock !
The bumpstop which came with the GC was more little than my OEM bumpstop cut in half, so the bumpstop are not too big.
Received 1,440 Likes
Rep Power: 338 Re: GC/yellow. bottoming out.
? fronts are supposed to have more travel than rears?
and wait, did you put front springs in the rear? don't. FWD needs stiffer asses.
I find that really strange that I have only the front which bottom out !
waiting for pics - hard to tell.
and the bumpstops are 1/2 the length of the stock ones, I would assume there would still be travel left.
course, the shorter spring could be a factor - was it bottoming before you swapped springs? however I would think the higher rates would keep the car slightly less deformation, but not sure of the suspension geometry ratio acting - aka, leverage effect from hub to shock attachment points - fronts are direct above, rears have a slight distance from the wheel, so there's a leverage effect there.
This is a picture.
And I doesn't try to put the good spring at there right place because I wanted slammed more the front of the car.
Thre rear is at the most lower. In the front, I have stil 1 inch and half on the sleeve, but it bottom out everytime at this height...
sunday, I just decided top remove my front GC and put my eibach sportline ! I am just 1/8 inch more high.... and I never never bottom out.
erm... we were waiting for the pictures of the assembly of the suspension...
Because I think that 375 it's too a low rate to slammed the car.
sdaidoji, sorry I don't have pict of the setup ! But all the pieces was in the good order !
when I will have a little bit time, I will put the good spring at their right place. I don't think that will make a diference.. but I will try
now i'm on my sportline
1 Post
It was either 375front and 475 rear
Or
475front 575 rear
But I know my spring rate is higher in the rear by 100.
I'll re read the thread later. I have a few hypothesis of what else could bt the issue
Or
475front 575 rear
dlg1985
07-23-2017 10:03 PM
robjcivic
03-12-2017 12:10 PM
Mannimarco
09-07-2015 10:01 PM
