Help! stock civic trying to beef up suspension
Rep Power: 0 Help! stock civic trying to beef up suspension
i have a 2004 honda civic coupe DX 1.7L SOHC and am trying to find some suspension upgrades and was wondering if anyone could direct me to parts or suggestions? it rides wayyy to lose and is constantly breaking from the road.
Received 1,146 Likes
Rep Power: 485 Re: Help! stock civic trying to beef up suspension
price range?
and what are you looking for? Lowered stance and slightly stiffer, adjustability in dampering/height, etc?
Rep Power: 0 Re: Help! stock civic trying to beef up suspension
lol price range i guess not insane performance parts. idk. i need it reasonable. and only want to drop it as little as needed. i live in new york and potholes are a bitch. definitly stiffer.
Rep Power: 787 Re: Help! stock civic trying to beef up suspension
prolly best bet is tokico hp shocks and eibach prokit springs (1 inch). firmer ride, looks nice, rides pretty good, and you wont mess up the car scraping or going over potholes. and it will grab the road better in corners.
rsx rear sway bar, stock front sway bar. neuspeed front upper strut bar. and moog endlinks front/rear for the swaybars. the front bar is usually pretty good stock, most civic come with large front bar to start with, and hollow for less weight. stock rear sway is way too small.
I'm looking to do this to my '02 lx. When you say rsx rear sway bar, I assume you mean that which would be stock for an '02 rsx, correct? Are there any particular brands that stand out?
I'm running a 19mm rear sway bar that actually came off of an RSX.. so.. honda OEM? lol.. I think I got mine off of clubrsx.com
1 Post
Rep Power: 266 Re: Help! stock civic trying to beef up suspension
Might as well pick up some better tires or a tire wheel combo. I put on a 21mm rsx rear bar and now I can really tell the tires are holding me back. Its a lot better for all around daily driving though.
Looking to make my 2000 sedan handle well for a daily driver on a tight budget . Should I go with the thickest sway bar possible with urethane bushings? Tires and springs will be last on the list due to cost... thanks in advance.
Rep Power: 183 Re: Help! stock civic trying to beef up suspension
^ welcome to civicforums
You should really be starting your own thread, rather than jacking someone else's.
Having said that, yes, the rear stabilizer bar is the best suspension mod you can do for the money. Find a used one to save cash - it'll work just fine. Get the thickest one you can (19mm is good, 22+mm even better). Be prepared to get new endlinks, too, just in case you have to cut your existing ones off.
Rep Power: 219 Re: Help! stock civic trying to beef up suspension
Sorry for digging this thing up. I will bring my car to the dealer to do the alignment since the price is pretty close to other shops.
Also, I called several shops for quotes of changing struts and to change 4 Tokico's on my civic 04. It costs around $920 (this place is the only one around north of Detroit that sells Tokico shocks and it is a performance shop)
I called the chained shop it about $900 but the chained shops use "MONROE." I had not asked which model they offer.
$900 is a lots if you can do DIY but since time and tools are my problem if I have to change I might go to that performance shop to do it.
I really want to try the Tokico HP
Rep Power: 210 Re: Help! stock civic trying to beef up suspension
*You will need an alignment kit, at least for the back, probably the front too: http://www.truehonda.com/inventory.p...products&id=27
See what the price is for them to put the strut/spring assembly together then put them in yourself. All you really need to R&R (remove and replace) is basic hand tools, jack and stands. A hand operated spring compressor is a bitch (believe me, I know). Let the shop take the risk of that spring coming off the compressor and slicing a hand off.
If you would rather just let the shop do it then by all means get the performance if it's just a bit more. Monroe sucks.
GH04si
04-15-2015 08:13 PM
WeRkX
11-01-2001 10:33 PM
