Ground Control Opinions
Rep Power: 0 Ground Control Opinions
So first of all I have searched on the forum in regards to the ground control sleeves, and can see that many are using them with Koni's. But I want to know what is anyones opinion towards the ground control sleeves. Such as, Spring Rate? Length of the spring? and any experience with other shocks/struts (KYB AGX, Tokico D-Spec or Blues), How the ride is? (Firm, Bouncy, etc)
I drive a 2002 LX Coupe and use my car as a daily driver with some spirited driving and through the mountain curves. I don't plan to drop lower than 1.5" because I will have a full lip kit and will be maintaining 15" wheels. I am looking for a setup that will be firm but also comfortable, and am usually the only person in my car. The other reason why I want something with height adjustment is to level out my car, due to driver side leaning from gas and driver weight on that side.
I may just go with the pro-kits and upgrade my shocks.
Thanks guys
Thanks guys
Rep Power: 257 Re: Ground Control Opinions
I went from Koni to Tokico blue, I prefer the Koni. I get more body roll with the tokico and the front likes to push. They are too soft for my liking especially the rear but are firmer than stock. Comfortable ride but just not sporty enough for me. I'd get the d-spec next time around. FYI i had these paired with springs 1.5" drop but I don't think you can go wrong with Ground Controls. Check out Boilermakers thread on them bc he recommends different springs for different setups.
Rep Power: 0 Re: Ground Control Opinions
Thanks ronaldo, I'll have a look into it. I remember reading up on the DIY install on the Koni shocks.
If anyone else has any opinions, feel free to post.
Well I was looking into coilovers, but the pricing for the Tein Basics from a local performance shop would charge me $1640.00 Canadian without install and without top mounts. If I were to go with a set of coilovers I would want a set that comes with everything for an easy install, such as Megan Racing. By all means I know that suspension is not cheap especially to do it the right way the first time around.
1 Post
Rep Power: 328 Re: Ground Control Opinions
as for an "easy" install, not soo much. is it doable with the right tools? totally. its just a paint in the lil *** to cut the tube, drill the hole, and insert them in. but are they worth it? every moment and even penny.
Rep Power: 296 Re: Ground Control Opinions
i agree, get some gc with koni's. I had them on my integra, they were a excellent combo. Don't get tein basics for the 7th gen. I had them on my 7th gen and they are crap. The rear shocks are too soft for those springs. Make the rear bounce like a low rider.
Thanks for all the replies everyone. I have heard lots of great things for koni, just the part of having to install is whats holding me back from them. The other options I was thinking of for struts are D Spec's or AGX.
What specific spring rates would you reccomend? I believe that I read in Boilermakers thread that for the rear he needed the spring length to be 6" also.
*Bump*
Anyone now which spring rates would be the best? Daily driver with spirited driving (Comfortable yet stiff to an extent)
Jap-Euro Fusion
Rep Power: 399 Re: Ground Control Opinions
Use the rates I've got posted in my thread. Its been so long I cant remember... (425/525?) Easiest thing to do is call GC direct, tell them you want the springs from the RSX kit with the civic mounts. Definitely make sure you get 6" springs for the rear though.
juror
Suspension DIY
07-30-2019 03:28 AM
califcamper
07-21-2015 10:34 PM
