Camber Kit.. Bolts.. Front Rear?
Rep Power: 0 Camber Kit.. Bolts.. Front Rear?
Yea the title is confusing.
http://www.tirerack.com/suspension/S...gory=Alignment
So I am getting the Ebachi Pro Kit Springs with the 1" or MAYBE the H and R sport 1.3" drop. Im leaning towards Ebachi becasue I've read alot of good things about them with Honda Users.
Now I dont know which Front and Rear Camber kit to get. Is the higher +/- what I want or a lower +/- (ex. 2.0-3.0 +/-)
I dont know how good Ingalls maybe, But for the 1" ProKit will the Ebachi front and rear camber kit hold up? Or should i get the Ingalls Front Camber and the Ebachi Rear?
I dont know how good some ebay camber kits maybe:
http://cgi.ebay.ca/WICKED-REAR-CAMBE...ayphotohosting
or
http://cgi.ebay.ca/Megan-Rear-Camber...QQcmdZViewItem
or
http://cgi.ebay.ca/RSX-02-04-CIVIC-0...ayphotohosting
Its for Daily Driving, Winter Driving, More So Family Sedan on Stock Shocks(for now)
Thanks.
or
or
Thanks.
Rep Power: 224 Re: Camber Kit.. Bolts.. Front Rear?
they're adjustable, but from experience, you may not even need a camber kit with the pro-kit. also, some ebay kits tend to not hold adjustment very well.
Rep Power: 234 Re: Camber Kit.. Bolts.. Front Rear?
you'd need an alignment a week or so after putting the prokits on to tell you if you need a camber kit. most likely the front won't need anything and you probably might need it in the rear either with that setup.
Rep Power: 0 Re: Camber Kit.. Bolts.. Front Rear?
Hmmm.. I wana get on this quick..
Only problem I have is my MagnaFlow Exhaust hangs way to low.. They have it going up as high as they could.. that thing is atleast like 2" off chasis. I get like a 2.5" clearance underneath. Or id lower it some more.
I've googled alota places, any of you guys have a best place to shop for Eibach ProKit and the SPC Camber Kit?
Looks like the Camber goes for about 150 + shipping taxes customs (canada) and the Springs from 240-275 depending on again shipping taxes and customs.
Does that look about right?
Rep Power: 240 Re: Camber Kit.. Bolts.. Front Rear?
i know from experience with the h&r springs you will not need a camber kit for the front, but will need one for the rear.
Rep Power: 200 Re: Camber Kit.. Bolts.. Front Rear?
get a SPC camber kit, and for the front get the higher 1 cuz ur not lowering that much.
and if ur only lower 1" u dont really need a camber kit
Rep Power: 253 Re: Camber Kit.. Bolts.. Front Rear?
I got Ingalls rear camber kit and its one piece forged and powered coated, so it wont rust for a while in the winter and its stronger than the SPC camber kit. Also, I've got Tokico HP Blue shocks on with Goldline springs, and you dont need a camber kit in the front unless you want some custom specs. I wanted to do -1.25 degrees in the front but the max it could go without front camber bolts is -0.9 and the max with in OEM spec on the data sheet shows -0.8. So even at a 2" drop, you dont really need a front camber bolt.
CapYoda
11-11-2001 05:17 PM
