Very Bouncy Ride. What to Do?
1 Post
Rep Power: 244 Very Bouncy Ride. What to Do?
i have a 2001 ex coupe and its runs fine. the only thing i kinda dislike is how it very bouncy going over cracked roads or bumpy roads. what would you pros suggest i change so i can get a better quality ride? oh, btw everything is stock. hope that made things easier. thanks alot everyone.
Look at me im a supporting member
Rep Power: 209 Re: Very Bouncy Ride. What to Do?
i for one dont know nothing about that kind of stuff what kind of stuff would you need to do to make it better
1 Post
Rep Power: 0 Re: Very Bouncy Ride. What to Do?
get aftermarket struts, and then get lowering springs, itll be a rougher ride but it wont be so bouncy, i have an 02 ex and an 01 lx and the lx is lowered and i like the ride much more, even though its bumpier
1 Post
Rep Power: 244 Re: Very Bouncy Ride. What to Do?
what kind of springs and struts are good, for a better ride and lowering?
and whats a camber kit i hear sometimes?
Rep Power: 450 Re: Very Bouncy Ride. What to Do?
camber kit straightens out the wheel after you lower it so you dont get uneven tire wear, when you lower it your car wheel will sit like this \ when looking at if from the back or front, a camber kit brings it back to stock like this l although it wont be that drastic
depends on how low you want to go, there are tons of setups
1 Post
and b4 u ask, YES u need a camber kit if u drop, but setup depends on how low u want to go, take a look around the suspension area under 7th gen, ull find a lot of answers there
Rep Power: 787 Re: Very Bouncy Ride. What to Do?
get better shocks, oem sucks. even a strut bar helps handling. i cant believe how people can drive this car in stock form. i couldnt even make a turn at 15mph without feeling like the car was gonna slide.
Rep Power: 280 Re: Very Bouncy Ride. What to Do?
well, if you want a more comfortable ride, i definately would not suggest you lower your car at all. that will just make it worse.
i would suggest you get some softer aftermarket springs, and some better struts (better dampening). that will be the answer to what you're looking for.
if I had your car I would invest in a full coil over system that has dampering that has 32 way ajustable and maybe that will solve your bouncing around and yeah get some camber kit like the member say and your ride should be smooth aights hope to see some pix on that setup .................
Bone Stock!
check out the review on Tokico hp with stock springs
https://www.civicforums.com/forums/1...k-springs.html
im getting tokico installed now with my prokit drop! finally lol. the stockers were on there over 50k miles and just started to leak.
Being on stock suspension, you could very well have a blown strut(s). It seems to be common for the stock struts to blow. In fact, one of mine is completely blown. I will be replacing them with Tokico Blue's as it is marginally more expensive for all 4 compared to 1 OEM strut from Honda. I'm not looking 'modify' this car, so comfort is a big thing for me.
Then why post?!
Then why post?!
This is Myspace
1 Post
Rep Power: 235 Re: Very Bouncy Ride. What to Do?
are there any aftermarket springs that do not lower ur car at all? i dont think so.. not that ive seen. maybe im wrong...anybody can verify? cuz that post makes no sense
1 Post
Rep Power: 328 Re: Very Bouncy Ride. What to Do?
^ teins Htechs...they lower ur car very very minimal and its a SMOOTHER and better ride...
htechs are made for comfort....and boy, when i had em for my accord, it was like flying on clouds.
1 Post
is the Tokico Blue's any good? i've seen many threads saying that they blow fast. is that true? and something like they cant handle stiff springs? what exactly are stiff springs? and does anyone know anything about kazera street sport springs?
well yea they blow fast because people are running them on huge drops which they were not designed for. 2 inch max for them, but i wouldnt go past 1.5 inch to be safe. i just got the fronts put on and really i cant notice much of a difference from stock. the ride just feels "newer" lol.
1 Post
Rep Power: 236 Re: Very Bouncy Ride. What to Do?
eibach pro-kit is a really good and dependable brand. they only drop 1.3"
I had them and they were soft as oem but stiff enough to take mildly fast turns with good stability.
why are you asking we have camber kits, just get one cause you need one unless you like buying tires every 6 months
Rep Power: 296 Re: Very Bouncy Ride. What to Do?
if you want the most comfortable ride. then just go with stock springs with aftermarket shocks. Most aftermaket springs are stiffer then stock, so you will have a rougher ride. Stock shocks should be fine for dd unless your shocks are blown or your driving over really large bumps too fast.
nah the stock is still too bouncy. i felt quite a difference switching to tokico. the stocks would let the car bounce up/down 3-4 times before settling down. the new tokicos bounce once and immediately settle again. and its not that the stocks were bad, actually one just blew a week ago, but two yrs ago when i first put the lowering spring on is when they got bouncy. heck even with stock spring the ride was bouncy. my dad commented on the rear bouncing on the second trip the dealer with 80 miles on the car
Bone Stock!
^haha yeah my dad was pissed too at how bouncy my stock civic was. after i got tokicos and yokohama tires, he was like hey your ride is more settled and less road noise (better tires)
omg stock civic, omg dont bring back terrible memories haha. with the crapstone tires that sounded like bus tires, and only lasted 18k miles before going bald, the terrible sound damping, horrible audio system that sounded like my clock radio, steering so bad i could barely take corners under 20mph, wow. amazing what a few mods and a ton of time can do lol
My cats breath smells like cat food.
Rep Power: 238 Re: Very Bouncy Ride. What to Do?
