Where's the RSX rear sway bar DIY?
Old Nov 24, 2004
IronFist's Avatar
There was one at xanja.com or something but it's down now. I'm asking for gearbox cuz I told him I would send him a link but I can't find it
Here's one for the Progress bar but that one talks about drilling holes and stuff, too. Is there one for just swapping the sway bars?
Old Nov 24, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
yeah i got a rsx-s rear swa bar with bushings and endlinks, but i cant figure out how to install them? what else do i need help us oh holy one.
Old Nov 24, 2004
TeLLy's Avatar
Yes, it's an Acura EL
1) Jack up the rear of the car (put it in gear if you've got a 5-speed), don't forget to block off the front tires just in case. Spray the endlink bolts and brackets with a little WD-40 or Liquid Wrench to help your loosening efforts.
2) The endlinks are held on by a 14mm nut over a bolt that has a slot for a 5mm Allen wrench opening. Looks almost like the top of the front strut assembly if you need a reference. Stick a 14mm wrench onto that nut and use a 5mm Allen wrench in that slot to hold the bolt in place otherwise it'll just spin with the nut. Took me a while to figure that one out.
3) Once the nut is off, just maneuver the endlink off the end of the sway bar, repeat for the other side.
4) The brackets that hold the sway bar to the subframe are 12 or 14mm nuts (I forget, but I think it's 12). Remove them, and the sway bar is now off. Remember how it looked when it was on, so you can match that with the new bar.
5) Remove the brackets from the bushings, you will reuse them. Laugh at your puny stock sway bar, then throw it at someone you don't like.
6) Put the RSX bushings on the new sway bar (I greased mine with lithium grease first, purely optional) then the brackets on top of them. Bolt to the subframe but don't tighten yet, you may need a little play when installing the endlinks.
7) Put the endlink bolts back through the corresponding holes in the sway bar then reattach the 14mm nut on top and tighten down. I had to use the 5mm Allen wrench to hold the middle part of the bolt in place while tightening.
8) Tighten the brackets, I forget the torque setting, so I just tightened them till good and snug.
9) Lower the car, check to make sure nothing is hitting the sway bar, like the lower control arms. If they ARE hitting, either you have installed the sway bar upside down or you have no springs or shocks installed.
10) Once all is good and tight, a nice easy test drive will show you how much better the car feels. Point and laugh at people driving Cavaliers and Sunfires.
11) Wash your dirty greasy hands off, you filthy animal.
Old Nov 24, 2004
gh0st's Avatar
TAQUITOS!!!!
^^^ rofl. nicely done sir.
took me a while to figure out #2 also.
Old Nov 24, 2004
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
I'm doing this on friday or on the weekend! thanks telly! u da MAN! a really funny one at that hahaha.. =]
Old Nov 24, 2004
robbclark1's Avatar
Retired suspension supermod.
Seth took it down from his website. So it isn't there anymore.
Old Nov 24, 2004
xam's Avatar
xam
i dont have a exhisting sway bar. what would i need. I have the rsx-s rear sway bar with the bushings and endlinks. i believe all i need is to drill a hole for the brackets and i dont have brackets where can i get them?
Old Nov 24, 2004
TeLLy's Avatar
Well, you'd have to drill a hole AND somehow thread it to accept the bolts that will hold the brackets on. Try to see if you can get your hands on the Neuspeed or Progress mounting plate....
Old Nov 24, 2004
nindoo's Avatar
Why is my vagina bleeding?
Install it following Grey DIY's. I know Grey's DIY is for the progress bar, but it should be pretty much the same only you don't need to mount the tie bar. You have the mounting points on your frame as well for the endlinks to fit to on your civic.
Old Nov 24, 2004
TeLLy's Avatar
Yes, but you'll need to find a way to fasten the bolts to the subframe - the Progress bar comes with those little "nutsert" things....
Old Nov 24, 2004
nindoo's Avatar
^^^^^^^^^^^Oh yeah I hear you I remember now. Thats why Grey had the addiotnal mounting kit(he called it) for the cars that didn't come with the rear sway bar from the factory.
Old Nov 24, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
also to add to telly's DIY, when i installed the RSX bar i stripped the allen key hole on one of the endlinks. So instead of using an allen key i used a pair of vise grips/pliers to grab a hold of a washer that is attached between the joint of the endlink and the bolt that needs to come off. If i would have known about this alternative from the start i would have done it first.
Old Nov 24, 2004
TeLLy's Avatar
I posted up a little while ago about how I had to do a similar thing...it was a funny story - I reposted it very recently too.
Old Dec 3, 2004
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
after you guys installed da bar, did you guys hear a popping noise after?
Old Dec 3, 2004
robbclark1's Avatar
No noise, make sure you didn't put it upside down.
Old Dec 3, 2004
CdKoInU's Avatar
its not upsided down
Old Dec 3, 2004
nindoo's Avatar
^^^^^^^ You sure check the progress images. Cause I put mine on upsidedown the first time.
Old Dec 3, 2004
CdKoInU's Avatar
i'm sure... already put it upside down da first time....
Old Dec 4, 2004
TeLLy's Avatar
Make sure your endlinks are bolted on nice and tight. And make sure they're not broken.
Old Sep 26, 2007
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
Re: Where's the RSX rear sway bar DIY?
where can i get rsx-s sway bar? and how much..
Old Sep 26, 2007
Zzyzx's Avatar
Autocross Junky
Walk to your nearest Acura Dealership and plop down $60 for the bar and maybe $15 for the bushings.
Old Sep 26, 2007
mrbanhbao's Avatar
what size (mm) do you suggest ? or anyone else..
Old Sep 26, 2007
they only come in one size-stock
Old Sep 26, 2007
DsevenEm2's Avatar
This is Myspace
so heres the freaking diy from Telly... doh! ok well...this weekend its finally getting on.. woohoo..slow mods ftw!
Old Oct 6, 2007
Em2_4life's Avatar
Em2_4life is an unknown quantity at this point
actually the bar cost 90 for just the bar and over 50 for the bushings and endlinks anyone have one forsale trade for front type s sway cuz i got the front one sent to me instead of rear
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
fordover
Jul 11, 2015 09:10 PM
