Squeaking noise on 04 civic after Tein SS install
Old 07-26-2004
thesparkleman's Avatar
thesparkleman is an unknown quantity at this point
I installed my new Tein SS suspension on my 04 Civic EX (SI in Canada) and all went pretty good until I took it for the test drive. A horrible squeaking noise was coming from the rear passager side. So, I took off the wheel and it seemed like the dust cover was not aligned properly. So, I moved it back into position, and put it back together. After a test run, that seemed to do the trick on the right side. But now I am hearing the same sound, only quieter coming from the left side. It does it most when you put pressure on the rear, rather that drive it. When you get in and out, it starts to squeak. Does anyone know weather this is common or not? Can I use so WD40 or something near the dust cover to try and eliminate this? Anyone have any other tips I could try. I am not very impressed right now as this suspension was quite expensive. Any help would be appreciated.
Old 07-26-2004
vtecpowersumo's Avatar
vtecpowersumo is an unknown quantity at this point
i had the same problem, i just got an exatoknife and took that dust cover off...
got rid of all noises
Old 07-26-2004
Thanks for the advice. Someone else mentioned that to me as well. I must admit I am a bit leary of just cutting them off. Maybe I will just remove them. What is the purpose of the dust cover and what will be affected by removing them?
Old 07-26-2004
The Standard One
VNlilMAN's Avatar
a dust cover just protects the shock from dirt and stuff. but yeah thats probably whats causing the noise. you dont HAVE to have it but its recommended you keep it. maybe just put grease around it or something. not wd-40, that washes off and i heard it eats rubber up anyways
Old 07-25-2007
Honda_Gay's Avatar
Honda_Gay is an unknown quantity at this point
Re: Squeaking noise on 04 civic after Tein SS install
This is to share a remedy on a common complain of the squeaky noise for the Tein SS suspension. I'm not sure if the problem is similar but use this only as a reference. I had this squeaky noise from the rear for couple of months, getting from bad to worse. The squeak will come on whenever my car go over a pothole or a hump, or any uneven undulations. I tried checking my Honda suspension bushing, oiling the joints and also inserting the rubber sleaves on the springs but to no avail. Finally, got the remedy for the irritating squeaks. The workshop remove the whole rear damper/spring assembly, and insert a thin rubber sheet between the spring and the damper (the cap that holds the spring in place). After reinstallation, we tested on some uneven undulations (and * touch wood) the noise is gone. No more squeaks ! Good luck!!!
Old 07-25-2007
Ti71's Avatar
Ti71 is an unknown quantity at this point
like others have said, trim the dust cover about 2.5 inches and it'll go away (I know because I had the same issues with my coilovers)
Old 07-25-2007
skipbarber's Avatar
i had the same problem, trim down the dust cover with a blade. 5 min. fix that works like a charm.
Old 07-25-2007
< My future wife.
armieo's Avatar
hey skip you're pretty much slammed on your teins right?
Old 07-25-2007
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Yeah trim the dust cover, but do not remove it completely. It prevents dirt from destroying the seals. I had a rip in mine that I was unaware of, and my struts blew. Could have been totally un-related but I am sure it didn't help.
Old 07-25-2007
skipbarber's Avatar
not quite, i have about a finger gap all around.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
ghondavic
Transmission
04-12-2017 09:37 PM
kanin247
Bolt-on Engine Performance
04-25-2015 05:44 AM
Thees1
04-14-2015 08:23 AM
Quick Reply: Squeaking noise on 04 civic after Tein SS install
