Hollow core vs Solid core sway bars
Old 07-04-2004
RedEU's Avatar
RedEU is an unknown quantity at this point
anyone know if there are significant difference between a solid cored sway bar & a hollow ones?
Old 07-04-2004
All Eyes On Z
SlammedBlueEM2's Avatar
Solid ownz all. It's of course heavier but the more resiliant it is to bending, the better the bar will do it's job. They are very worth it.
Old 07-06-2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Weight. In fact, I might tinker with my 19mm rear swaybar instead of getting a 22mm to save weight and money.
Old 07-06-2004
Autocross Junky
Zzyzx's Avatar
Torsionally there is very little difference between a hollow bar and a solid bar, a solid bar would be stronger then a hollow bar of the same diamiter, but not by much. (Depending on the thickness of the walls that the hollow bar has).
Good info on the subject...http://www.miracerros.com/mustang/sway2.htm
Old 07-07-2004
El Pinche Turbo Mexicano
CivicMexicano's Avatar
CivicMexicano is an unknown quantity at this point
is there any modification needed for the 19mm bar, like endlinks or just bolt in place....
Old 07-07-2004
Sickboy's Avatar
As long as you already have the stock one, just unbolt and bolt in new one. If you don't already have one you need a mounting kit to attach it to your control arms.
Old 07-07-2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
What about new bushings ?
Old 07-07-2004
Sickboy's Avatar
Thanks, you also need new bushings. The stock brackets will work with 12mm,13mm, and 19mm rear sway bars, not sure about the 22mm though.
Old 07-09-2004
DIY King
Grey's Avatar
To put it another way... A hollow bar needs to be of a bigger diameter to have the same twisting stiffness as a solid bar, but it will weigh less.
Old 07-09-2004
Yes, it's an Acura EL
TeLLy's Avatar
I have the 22mm bar, and when I got it from my sponsor he was going to give me just the bushings. According to him, they fit with the stock brackets. But I was a pushy little bastard and got him to give me Energy Suspension bushings (brackets included) instead, so I can't verify this.
Old 07-11-2004
All Eyes On Z
Absolutely unnesessary. Those brackets are all the same if your bar is OEM, they just look different. There was this big debate in the past about the bracket's purpose. The stock ones are fine. I've had mine on for 2 years and no issue.
You should've pestered him to get you some Energy Suspension 22mm bushings. That would've supplemented the bar's performance.
Old 07-11-2004
HoldDaMayo's Avatar
HoldDaMayo is an unknown quantity at this point
as a side note here... I've got a 25mm EX sway bar I'm putting on my LX... is it worth it for me to buy the energy suspension bushings?
SammySC
121
04-07-2017 07:43 PM
cferry7
10-03-2015 04:33 PM
Raiool
10-01-2015 10:42 AM
rovafa2002
09-28-2015 06:57 PM
Viczhou
09-02-2015 07:55 PM
Quick Reply: Hollow core vs Solid core sway bars
