koni yellow and Ground Control coilovers
Rep Power: 0 koni yellow and Ground Control coilovers
is koni yellow struts and Ground Control coilovers any good for a 2001 honda civic LX im not looink for a race set up more for a good ride and slam the car to the gound
IDEAS?
IDEAS?
Rep Power: 0 you're not going to get a good smooth ride if your slam your car. the lower you go, the harsher the ride will be. but yes, the koni and GC set-up is a good one. but dont expect a ride similar to stock
Search and Learn
Rep Power: 407 Originally posted by 01nightrider
is that what you have on you civic and were is the best palce to get them from
he has b&g full coilovers
The Standard One
Rep Power: 392 gc = $300
konis = $550
why not spend a couple hundred more and get true coilovers. b&gs can slam your ride.
reason why i would spend the extra for true coilovers is they are designed to work with spring/shock. also people have complained about the koni perches breaking off. koni shocks arent shortened.
konis = $550
Search and Learn
Rep Power: 407 Originally posted by VNlilMAN
gc = $300
konis = $550
gc = $300
konis = $550
save up more and invest full coilovers.
you wont regret.
Rep Power: 0 i got koni and gc... my rear perch broke but i got it welded on and its ok now... but i would recommend b&g if you want to slam your car, and tein for performace... i wish i could've saved up for a full coilover setup, but its too late now...
