No Camber kit.....
Old Apr 13, 2003
Project2k2's Avatar
No Camber kit.....
Ok, if I don't have the cash to put on a camber kit, how long is long enough to ride without the camber adjusted? Is it that bad if it is not adjusted for a month?
-Derek
Old Apr 13, 2003
flotsamm's Avatar
Just keep an eye on your tires inner tread, when it starts to show uneven wear you should consider installing a kit.
Old Apr 13, 2003
Project2k2's Avatar
I know but how long does it usually take? I am dropping it with goldlines if that helps any.
Old Apr 13, 2003
flotsamm's Avatar
I dont think you can put a time on when since theres to many variables to take into account. Your driving style, roads, suspension setup, how many miles you drive, etc all play a role in how long your tires will last. So all you can is keep an eye on them, or get it corrected with a kit. But its not like there gonna wear out in a week or sumptin.. Maybe check for wear every month or so.
Old Apr 14, 2003
brents1's Avatar
brents1 is an unknown quantity at this point
I let mine go for a 3 weeks w/ goldlines. the insides of my tires were worn a lot. I would advise you to wait till you get enough money to buy a camber kit before you install your springs. But a lot of it depends on what flotsamm said. I drive at lease 75mi every day.
Old Apr 14, 2003
RedDragon333's Avatar
all depends on your driving conditions, my friend has some sportlines that drop his car around 2in on his accord and hes tries took 6mons to wear. It all depends but wait and save an extra 159 and grab the SPC camber kit, roll with the best. YOull save more money in the long run that installing the springs now and replacing the tires in the next 6mons or so.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
