A QUESTIOIN
A QUESTIOIN
I just put on goldlines...before my car was running to the right alittle...after the alignment it still pulls a little to the right..is this goin to mess my tires up...they said they did a suspension alignment
DIY King
If it pulls to the left or right it's the alignment. The camber and the toe. It has nothing to do with the balancing of the wheels. If your steering wheel shakes then you need your wheels balanced. If it pulls to one side or another while driving then you need an alignment. If it pulls to one side or another while braking and not while driving then you need a brake job. It's that simple.
As a suggestion, try swapping the front and rear tires around and test. If it still pulls then get perhaps look into getting an alignement.
