TEIN SS Adjustment Knob
Old Mar 23, 2003
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
TEIN SS Adjustment ****
Wussup peoples... I was wondering if anyone ever had a problem with the adjuster know on the TEIN SS. I adjusted the **** on three to setting #10 and when I got the 4th one it did not budge. I set all 3 back to the standard setting cuz I did not want to screw anything up.. any one have any ideas or should I just go back to the shop that installed the suspension...
Old Mar 24, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Drive around with the stock setup and break in the coils. Try to adjust them again after 100 miles. It also depends on how you rotate the ****. Try different angles, different direction, and give it a little force. They are made tougher than you think. They did have to take in account customers trying to do things themselves. But if you have the time, take it to the professionals. They should not mind, it would take them a couple of minutes.
Old Mar 24, 2003
Elite's Avatar
Elite is an unknown quantity at this point
if you have full warantee go ahead and adjust them if they break charge the shop for not installing the coilovers right, its not your fault that they broke right, they have warantee otherwise take it to the shop and tell them to adjust it.
Old Mar 24, 2003
True I was thinking of going back to the shop.
I tried again today and it moved one back but got stuck again... guess I will be going to the shop this weekend. Thanks guys..
Old Mar 25, 2003
ASWZero's Avatar
Let the shop do it, they break they pay for it. Just as long as you do not get stuck with falty coils. I doubt it is the coils. Tein is not known to be that sloppy. Once it is out of the hands of Tein, anything can happen. Choose your shops wisely.
Old Mar 27, 2003
went back to the shop, they called tein and they want the coil setup from that right front shipped to them so they can check it out... The shop said the problem is in that adjust **** seems to be stuck. They asked if I went over 16 which I did not even get to change it from the standard setup of 6... Great Now I have to wait 2weeks...
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Jrosa
Sep 14, 2015 08:24 PM
