2001 civic ex clunking upfront - Honda Civic Forum
Old 08-26-2009
gzulauf is an unknown quantity at this point
Car drives/handles fine straight or turning. Clunking is heard near front right wheel when hitting small or large road bumps. clunking continues for a very short time after hitting the bump. checked muffler hangers-ok.
gzulauf is offline
Old 08-26-2009
Hanzo's Avatar
Hanzo has a spectacular aura aboutHanzo has a spectacular aura aboutHanzo has a spectacular aura about
Re: 2001 civic ex clunking upfront
Sounds like your lower control arm bushing is done. You can get it replaced or you can just have a shop replace the whole control arm. It depends on the shop. Some shops can replace the bushing only and some shops tend to only replace the whole lower control arm assembly
Hanzo is offline
Old 08-27-2009
THANKS Honzo for reply. Had vehicle checked (quickly) by mechanic. Said strut isthe problem. I am not so sure. Had tires rotated and balanced - no evidnece of cupping, uneven wear. Listening carefully to suspension noise, I notice the noise disappears/lessens on turns-even though road bumps are present. Doesn't this suggest worn stabilizer/sway bar bushings? THANKS
gzulauf is offline
Old 08-28-2009
djmota's Avatar
I Think its the lca compliance bushing also, but one thing it could be is a worn sway bar end link. My wifes 2001 crv was clunking pretty bad and it turned out to be the endlinks on the front sway bar. It would clunk especially when it went over bumps.
djmota is offline
Old 08-30-2009
Solved the problem. Yes, the sway bar links were the problem. I purchased for $30 and installed. No more clunking! Drives beautifully. Especially feels good to have saved nearly $600. THANKS Honzo for your replies. My impression is that mechanics may use the strategy of offering the highest cost option ($600), then when the problem is not solved will offer to fix for free ($30 in parts) and they still come out way ahead. They wouldn't do this would they????
gzulauf is offline
Old 09-01-2009
Atromos is an unknown quantity at this point
Is the pope catholic?
Atromos is offline
Old 09-08-2009
ddddyyyy is an unknown quantity at this point
Oh, my dear,Imiss you very much,I think everything will better,That good things!
A faithful friend is hard to find.
nfl jerseys ugg r4 Designer handbags rolex NFL jerseys
ddddyyyy is offline
Old 09-13-2009
RyanOrlando's Avatar
RyanOrlando is an unknown quantity at this point
Sounds like a bushing if it sort of "bounces" off cracks, also possibly could be your struts. Id say it is your lower control arm and bushing.
RyanOrlando is offline
Old 10-15-2009
jala is an unknown quantity at this point
I have the clunking and rattling in front of my 01 civic....I have changed struts, stabilizer links, LCA and nothing has changed...I am fed up...Have taken it to at least 4 mechanics and none have been able to fix it.....
jala is offline
Old 10-22-2009
ParkLake is an unknown quantity at this point
Jala- I have the exact same problem and I'm not going to bother fixing it. We can to take into consideration that our year was the test dummy one, but I won't purchase or recommend a Honda any longer.
ParkLake is offline
Old 12-07-2009
metalhed454 is an unknown quantity at this point
Guys I have the same clunking prob w/my 02 Civic EX, on the right front. I removed the wheel and saw that the front bushing (compliance??) on the LCA is gone, take a look. This bushing started to go at around 65k miles.
Question now is, should I use an OEM replacement or an aftermarket one, possibly a neoprene bushing that might last longer?
metalhed454 is offline
Old 12-18-2009
triplej is an unknown quantity at this point
Thanks for the tip, my 02 ex is doing the exact same thing..70k miles.
Another option when your having front-end problems,take it to a good alignment specialist who will tell you exactly what part needs to be replaced. Fortunately I have one who will do this, of course there is a fee involved. I then replace the parts and take back for alignment…save you big bucks and headache.
triplej is offline
Old 03-24-2015
cowboys2015 is an unknown quantity at this point
Sounds like an engine/transmission mount somewhere.
cowboys2015 is offline
Old 03-24-2015
emich is an unknown quantity at this point
knocking sound could indicate bad ball joints. I found today this is the reason in mine 2001 EX both sides. Duralast **** lasted less than 2 years.
emich is offline
Old 10-13-2015
shinobi9 is an unknown quantity at this point
I think the Honda LCA bushings are kind of weak... I've replaced mine with some polyurethane ones from amazon, so far so good.
It was easy to see the play in mine though, they were really shot.
shinobi9 is offline
Old 06-16-2016
Yellowbeard is an unknown quantity at this point
Hi. I am having similar issues. 2001 Honda civic LX 5-speed stick with about 160k. There is a clunk sound (and a clunk I can feel, slightly, through contact with the gas pedal/floorboard) seemingly coming from the right(ish) side of the car. So far I have replaced:
ball joints on both sides
struts on both sides
lower control arm bushings on both sides
sway bar links on both sides
brake calipers on both sides
bearings on both sides
CV joint on the passenger side (but only because I stupidly managed to mushroom it when I was trying to get it out to replace the bearing on that side).
Just FYI, most, if not all of these parts needed replacing, so they didn't get replaced simply chasing the clunk.
However, I am understandably frustrated that the clunk remains (in fact, seems worse).
I haven't yet replaced any transmission or engine mounts (or even inspected them) so maybe cowboys2015 has my answer?
Thoughts?
Yellowbeard is offline
Old 06-17-2016
AlexFromCali's Avatar
AlexFromCali is an unknown quantity at this point
Got to love new sway bar links, they operate fantastically, especially that some are updated with better materials.
AlexFromCali is offline
Old 06-17-2016
I retrofitted a grease nozzle and grinded it so that it would give clearance for the cv axle boot.
Now I just grease it and the old **** overflows and comes out. Keeps my ball joints 100%
Old 06-17-2016
Some brands like MOOG are sturdy! The machine shop that pressed them in said they are good quality, and updated designs for the OEM replacement.
Old 05-06-2017
bump.
Old 06-20-2017
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
I had the same issue, lower control arm. It is a lot easier to replace the whole control arm instead of pressing bushings in my opinion. Took care of the clunking in my case. My 2 cents
SammySC is offline
mattdoc
03-14-2017 01:10 PM
bambuski
11-12-2001 11:35 PM
CapYoda
11-11-2001 06:17 PM
Lightman
11-10-2001 07:44 PM
liljoe
11-04-2001 02:27 PM
Quick Reply: 2001 civic ex clunking upfront
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
