Front Upper Strut bolt question (for all diy'ers)
Well, the upper mounts on my b&gs have **** the bed. One nut/bolt on either side in the front just spins and I cant break the nut off of the tower to remove them.
Is there a way to somehow hold the bolt from the underside so I can take the nut off? I forgot completely what the stock upper mounts look like.. Anyone? Bueller...
Take it to a shop. I had the same problem when I wanted to change strut bar from a cheapo ebay bar to neuspeed strut bar. The bolt was stripped so I first tried to break it off and rethread it but we couldn't. I took it to shop and they had to take out the whole strut assembly from the bottom to remove it. New top mounts cost me like 100 bucks.
I'll take a look at my B&Gs when I get home tonight. I know everytime we've run across this problem at our shop, we've realized that vice giprs/ large channel lock pliers can be your best friend...
And so can the hammer and torch.
thanks for the input but im going to take them off anyway to send the front struts to be rebuilt.
to clarify, which is hard to explain, can I remove the bolts by jacking the car up and working from the bottom up on them? Is there a way to get channel locks around the bolt to hold it in place while I work the nut from the top?
thanks all.
thanks all.
just checked out the bottom of the upper mount. doesn't look like there's gonna be a way to hold if from the bottom, unless you use the slit/screwdriver method and try to notch the bolt head with a dremel or something and then use a screwdriver from underneath.
****, thanks for the information.
OK, this is just what I'de try. Put a slit it the top of the bolt (dremel-whatever), put the socket on the nut with a screwdriver thru the center hole. A screwdriver with a nut section near handle (snap-on) will help as will a socket with a "nut" section on top. Otherwise visegrips!
Good luck
Getto, but works!
Remove the other nuts and put a pickel-bar (ball joint remover) or screwdrivers under the open area, aka pry up on the top while loosening. An air wrench really helps!
Good luck
Getto, but works!
thanks pon. the second one may work if i can get enough force on the bolt. btw both sides have a stripped bolt....f*uckkkk
wish i could man, its a damn process to jack up my car, thats why i am asking. i hopefully will jack it up this weekend...
Yeah I know what you mean man. Mines lowered on the eibach sportlines, which isnt too bad. I still have to lay two 2x6"s down roll back up on top of the first one and then the second and then I can fit my jack under it. I try to do it as little as possible.
GH04si
Apr 15, 2015 08:13 PM
