Brake booster upgrade?
Rep Power: 0 Brake booster upgrade?
Okay so I owned a 2014 focus and absolutely loved how sensitive the brakes were. Unfortunately lost it and I now own a 01 Civic EX and have been looking into how to make them more sensitive and what I have taken from my research is that I’m going to need to upgrade my brake booster. What Master cylinder/power brake boosters are interchangeable with my car? What’s the best option? Opinions? Tips? Advice?
Dr Krieger of Modification
Re: Brake booster upgrade?
For performance
-Slotted rotors to cool better.
-A good set of racing pads, something top shelf from Hawk.
-Dot4 fluid swap
-proper bleed at all four corners.
For feel
-braided steel lines with silicone coating.
-Dot4 fluid swap
For feel
The following users liked this post:
sweeney.b (05-13-2021)
I don't know that you will find an upgraded brake booster for one of these cars. A quick Google search didn't find anything. I have an 05 and IMO the brakes always worked well when they were functioning correctly, and after the upgrades listed above the brakes work great. So if your brakes are unresponsive, I'd start with checking the system for problems, like worn pads or improperly adjusted shoes. But remember that on most cars, the limiting factor for stopping distance is TIRES, not brakes.
Prelude Owner
Every Ford I get into and drive I slam on the brakes for the first hour or so because they are so darn touchy lol. Too much I think!
It will take some time to get used to it but you might end up liking it.
Rep Power: 77 Re: Brake booster upgrade?
the brakes in my mustang squeaked so i went on a mission to upgrade them...
i bought drilled/slotted rotors, new bearings, and then got pads from the dealer. my thinking was that the rotors would help with brake fade and using factory pads they would be the least likely to squeak as. OEM pads are usually chamfered to reduce noise, have anti rattle clips, and make a fairly low amount of dust. after my "upgrade", my brakes actually feel a bit worse than they did with the crappy junk i removed, but they're quiet. i think the rotors having less surface area (due to all the cool looking holes and slots) is counter productive in a daily driver. a regular properly surfaced rotor will have more contact with the brake pad and more initial bite. it's something i read, but ignored. i shouldn't have. i plan to ditch the cool looking rotors. i'm like you in that i want more initial grip. most of my panic stops are at sane speeds during rush hour. brake fade is not a problem for a driver that drives sane.
for pads, you can ask companies for recommendations. Raybestos makes all varieties of brakes from economical to nascar. my friend built a 700 hp GTO for raybestos that actually has nascar brakes, and i remember commenting that the brakes squeaked. i thought it was funny, but i learned from it. http://www.hotrodchassisandcycle.com/1964_GTO.php
i would stick to a sane pad and a regular rotor. SS brake lines in front and a complete fluid flush is where i would start. the SS lines really help with a spongy pedal. it will start you in the right direction and won't break the bank... or you might look into the brakes on an SI version of your same year as they MIGHT be a bit bigger/better?
here's what i did that i now need to fix. they're pretty, but also pretty disappointing. the rusty rotors and cracked pads stopped faster
Prelude Owner
I did an EBC green stuff and slotted rotor upgrade to my Fit. Very nice improvement over stock. Initial bite feels OEM but when pushed she stops much better. Zero noise too. More dust but I spray this brake dust repellent on it and it helps. I have a set of SS silicon coated lines but have not installed them yet.
PhAtTysSiVi
08-09-2002 04:36 AM
