Parking Brake Problem?
Old 09-10-2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
2003 ACURA EL with rear disc brakes
Last week had to stop as right rear wheel was smoking after a noise (like a ping or spring). Stopped immediately and wheel was smoking. Continued on to shop and made an appt.
They looked it over and found nothing wrong. Told them to specifically check the parking brake mechanisms as I had suspected something gave way and caused the issue. Not sure if they actually did - I usually have great service from them.
Over the weekend I removed cover to parking brake lever and cables and found the right rear cable to be looser than the left. Not by much but the left cable is the one that is engaging the most.
Does this indicate a parking brake problem at the right rear? Removing the wheel is not an option for me personally.
Old 09-10-2018
Colin42's Avatar
Received 1,126 Likes on 941 Posts
Re: Parking Brake Problem?
sounds like the caliper is seized or the parking brake mech is seized on a bit
Old 09-24-2018
NDNV's Avatar
Tightened the adjustment nut at the hand lever area and seems fine now.
tekcap
Brakes
05-27-2019 10:57 AM
NightHawk04
Brakes DIY
10-12-2017 09:25 PM
brags
04-30-2017 06:30 PM
sawdust_tom
Wheels and Tires
08-22-2010 10:16 PM
gearbox
Wheels and Tires
01-28-2009 04:41 PM
Quick Reply: Parking Brake Problem?
