Brake problem?
Old 04-11-2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Brake problem?
Ok so when I stop it’s either my front or my rear I can’t really tell which one but it scrubs when I stop. It’s a weird noise because it’s like in one spot cause it’s only when it hits that one spot as the wheel turns. But it’s only when I stop. Can I diagnose it by jacking the front up and turning the wheel and listening or do I have to take the tire off and all that? My rear shoes were just replaced 2 weeks ago.
Old 04-11-2018
Slumpertcivic's Avatar
Re: Brake problem?
If your not feeling any steering vibration when braking I would start with jacking up the rear, rotating the wheels while someone lightly touches the pedal.
Will take a bit of patience for you and the pedal pusher to work out, but you should be able to quickly find if one of your drums is out of round.
Old 04-11-2018
Re: Brake problem?
the only time it shakes when braking is when I have to hard brake or going down a hill it shakes, but I know it’s time for new rotors and pads but the scrubbing is what I can’t figure out
Old 04-11-2018
mikey1's Avatar
Re: Brake problem?
could be your front pads worn down to the metal,
could also be the wear indicator on the front pads touching the rotor
Old 04-12-2018
Re: Brake problem?
WWSWD?
Stick your head out the window and turn your head sideways.
Old 04-12-2018
Re: Brake problem?
Originally Posted by ezone
WWSWD?
Even better when someone else is driving/stopping
tamazoid
04-28-2005 12:34 PM
GreatWhite02
04-20-2005 09:54 PM
streetglower
09-07-2003 11:07 PM
CapYoda
03-31-2003 02:54 PM
Sarvic
08-29-2002 07:18 PM
Quick Reply: Brake problem?
