Hubcap question. Need someone’s help.
Rep Power: 0 Hubcap question. Need someone’s help.
Ok, so I broke a hubcap and they are factory so they are Honda’s bolt-on hubcap and I really don’t want to spend $65 a piece for new ones. But I recently spray painted my rims black with the plasti dip idea and it turned out wonderful but I hate seeing my car without hubcaps it looks stupid. So my question is, since it’s really hard to find black bolt on 14 inch 4 lug hubcaps, will the universal ones fit? Or would I be better off buying some cheesy chrome ones that are bolt on and call it a day?
Super Moderator
Received 1,853 Likes
Rep Power: 196 Re: Hubcap question. Need someone’s help.
My local pick-a-part has the hub cap price listed as $5.99.
Received 1,126 Likes
Rep Power: 191 Re: Hubcap question. Need someone’s help.
they'll fit but they're way more likely to fall off because they're not held on with the lugs like the oem ones
Rep Power: 0 Re: Hubcap question. Need someone’s help.
So since it’s nearly impossible to find decently cheap hubcaps for my car that are bolt on, could I convert to the snap on style by changing my lugnuts to a shorter type so the hubcap will fit?
there's no junkyards near you?
if Fit's came with 14" wheels those will work as well.
can try car-part.com also.
the aftermarket ones don't fit?
Honda uses ball end lugnuts instead of the normal acorn type, im not sure if they make open end ones with the ball
