How do I adjust drum brakes? - Honda Civic Forum
Wheels, Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here
LinkBack Thread Tools Search this Thread
Old 12-29-2017   #1
D17VTECPOWER's Avatar
D17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really nice
I am going to be changing the brake drums and shoes on my 2005 Civic for the first time in 231K miles, but I am a little confused on how to adjust them. I know how to adjust them, but I am not sure what the 'proper' adjustment is. Am I correct in presuming that I should adjust the brakes so the shoes are as close to the drum as I can get them without the brakes dragging? Thanks, I haven't changed drum brakes before, so I am unsure of how to know when the brakes are properly adjusted.
D17VTECPOWER is offline   Reply With Quote
Old 12-30-2017   #2
Super Moderator
sdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to beholdsdaidoji is a splendid one to behold
Re: How do I adjust drum brakes?
I *think* they were automatic adjustments.
I personally only opened them once to find the shoes were as new as the new ones i had to go in, so never disassembled them.
just don't let them be too collapsed, or the cylinders could pop out when you step on pedal first time. (all that holds them is the shoes against the drum)
sdaidoji is offline   Reply With Quote
Old 12-31-2017   #3
Where's that music coming from?
They are self adjusting, but you still have to set up the initial adjustment correctly during assembly.
Megalodong? Mikey?
ezone is offline   Reply With Quote
Old 12-31-2017   #4
The Dongerator
Megalodong's Avatar
Megalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to beholdMegalodong is a splendid one to behold
Quote:
Originally Posted by ezone View Post
They are self adjusting, but you still have to set up the initial adjustment correctly during assembly. Megalodong?
I concur.
I'm not sure if I did it right but it came down to taking the rim/tire off, adjust start wheel, put tire back on, spin tire, brake: my mom would alternately (on my signal) would either use the foot brake or hand brake. Took about four cycles of tire off/on, adjust star wheel, spin tire, hand/foot brake to find a balance between the tire spinning freely when no brakes applied and tire stopping well when either the hand or foot brake applied.
Ezone (as a follow-up to a PM)...my mom's car's brake pedal feels solid and isn't mushy so, I assume it's adjusted correctly. The hand brake function is much better than it was prior to star wheel adjustment on the passenger side rear. I still feel the hand brake should engage sooner so I may adjust tension under the center console. Will tension one click at a time.
Megalodong is offline   Reply With Quote
Old 12-31-2017   #5
Do ONE SIDE AT A TIME, so you can look at the unmolested side to see how it's supposed to be assembled. NEVER take apart both sides at once (this rule applies to me too!)
Initial adjustment:
Drum off, shoes/springs/linkage correctly assembled, handbrake fully released, cables slack, mechanisms in drums all the way back (no sticking cables)
Crank up the adjuster to widen the link
periodically check if the drum fits over the shoes or not
As soon as the drum won't go on, back off the adjuster about 4 clicks and retry, repeat until drum will slip on
To back off the adjuster you must first release (pull out) the self adjuster lever away from the toothed portion of the star wheel, as it is designed to only work one direction. You can spin the wheel one way and the teeth ratchet past the lever but it tries to lock when you turn it the opposite direction.
You want to make it so the drum slips on without binding on the shoes and will turn without binding on the shoes. A small amount of drag as it spins is ok but it has to be free enough to turn the bare drum by hand.
If shoe adjustment is too loose, the pedal will feel low and the handbrake will be high.
If adjustment is too tight, you will have a helluva time getting the drum off to readjust, and the brake will drag and overheat.
It's a huge PITA to back the adjuster off if the drum is stuck, so don't get it stuck.
Old 01-01-2018   #6
The Dongerator
Megalodong's Avatar
Not intending to hijack OP's thread but this is the part that I may not have done correctly. I do remember trying to spin the hub first without the tire and since it didn't seem to spin easily I would put the tire back on to rotate. I'll pull the drum off again and see if it comes off without too much resistance.
Old 01-01-2018   #7
Quote:
If you've been driving it without a problem, it's probably not a problem
Thread Thread Starter Honda Civic Forum Replies Last Post
Replacing Drum Brakes with Disc Brakes Hondaboy25 Wheels, Tires & Brakes 0 05-16-2012 06:47 PM
Clean and adjust rear brakes for 2005 Civic sedan? nyyanks81 Wheels, Tires & Brakes 10 11-05-2008 11:44 AM
Question about Tools for Drum Brakes, or to those who have Serviced Drum Brakes? streetglower Wheels, Tires & Brakes 3 01-05-2005 02:18 PM
how toconvert from drum to disc brakes? Doug Wheels, Tires & Brakes 0 08-04-2002 04:30 PM
Does anyone know how to adjust the rear brakes on our 7th Gen solar Wheels, Tires & Brakes 0 06-05-2002 11:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
