Unusual Wheel Shaking??? - Honda Civic Forum
Wheels, Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here
LinkBack Thread Tools Search this Thread
Old 10-01-2017   #1
zubairq16 is an unknown quantity at this point
Angry Unusual Wheel Shaking???
I have a 2005 Honda Civic Ex Coupe with 205,000 miles.
I recently had the following this changed:
- Both wheel bearings in the front
- Lower control arm bushings
- Ball joint
- Tie rod end
- New tires with balance
- Alignment
When I drive my car on highway speeds the car starts shaking. It's pretty constant shaking and there is no range of speed at which the car shakes more or less, as soon as I go above 60 there is a constant shake even at 100. No shaking at all below 60. I did suspension test on my car bouncing up and down and suspension seems fine.
What could possibly be causing my car to shake????
zubairq16 is offline   Reply With Quote
Old 10-01-2017   #2
Where's that music coming from?
Re: Unusual Wheel Shaking???
Are the wheels stock?
If aftermarket wheels, are the centering rings all correctly installed?
Take it back to whomever installed and balanced the new tires and have them drive it--or you take them for a ride to demonstrate the issue. Probably needs balance redone.
ezone is online now   Reply With Quote
Old 10-01-2017   #3
I'm such a Ricer!
mac25's Avatar
mac25 is a glorious beacon of lightmac25 is a glorious beacon of lightmac25 is a glorious beacon of lightmac25 is a glorious beacon of lightmac25 is a glorious beacon of lightmac25 is a glorious beacon of lightmac25 is a glorious beacon of light
Did you or someone else hit anything hard with the wheel after the balance? The rim may be bent or a segment of weights could have fallen off.
I agree withe Ezone, return to the balancing shop for verification.
mac25 is offline   Reply With Quote
Old 10-02-2017   #4
NDNV's Avatar
NDNV is on a distinguished road
EGR system blocked with carbon buildup?
NDNV is offline   Reply With Quote
Old 10-07-2017   #5
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
Get your tires rebalance at another shop. I had a similar issue when I bought my tires and they shop balance them 3 times and same issue. I took it to another shop that had a 15 year old balancer and 3 of the tires were out of balance. These new balancers needs to be calibrate on a regally basic which most shop don't do or they don't do it at all.
nsrhonda89 is offline   Reply With Quote
Tags
alignment, balance, control arm, shaking, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
