02 civic offset wheels
Rep Power: 0 02 civic offset wheels
Hey I have a 2002 honda civic and im intrested in buying a set of esm 002r sl wheels they are 4×100 bolt pattern with a 35 offset. 16× 7.5. With a 73.1 mm bore I want to know if these wheels will fit on my car or will I have to do any special specifications? I also wanted to do a stretched tire for the wheels also . If not does anyone know whats the biggest offset I can go with out any cutting or what would be the best offset with stretched tires for my car ???
Looking for an Alpha Romeo GTV6
Rep Power: 0 Re: 02 civic offset wheels
Vehicle Make & Model Year Range Bolt Pattern Wheel Size Range Wheel Offset Range
Honda Civic All 1988 to 2000 4x100 (14x5.5) to (17x7) +35mm to +45mm
Honda Civic All Except Si 2001 to 2005 4x100 (14x5.5) to (17x7) +35mm to +45mm
Honda Civic Si 2002 to 2003 4x100 (15x6) to (17x7.5) +35mm to +45mm
Honda Civic Si 2004 to 2005 5x114.3 (16x6.5) to (18x7.5) +35mm to +45mm
Honda Civic All Except Si 2006 to 2013 5x114.3 (15x6) to (17x7.5) +38mm to +48mm
Honda Civic Si 2006 to 2013 5x114.3 (17x7) to (19x8) +38mm to +48mm
Rep Power: 190 Re: 02 civic offset wheels
how low are you? how much camber do you want to run? what type of look are you going for? I'm on 17x8 with a +27 offset but my fenders a rolled and I'm running a bit of camber
Anyone know what size tire to run on 16x8 +20 offset not looking to stretch really want to keep a hard stance and I’m lowered on true hart 2 inch lowering springs
Prelude Owner
I don't what that means?
You are going to need at least a 225-245 wide tire. Use this calculator to help you determine the size that will keep your gauges accurate.
https://www.tacomaworld.com/tirecalc
We have one too that has different info:
https://www.civicforums.com/forums/t...calculator.php
tomas6791
09-11-2015 06:47 PM
