p206/60r15 tires OK on stock 02 EX coupe?
Old 08-01-2012
QFT
QFT's Avatar
QFT is an unknown quantity at this point
My girlfriend just got this car (steel wheels), and it has winter tires on the way out. Her previous car (98 Contour, being junked) has almost brand new p206/60r15 tires. I spoke with TireRack and they say the size SHOULD fit, but they might be a little tall (too close for them to call)
Anyone have any experience with this size tire on these Civics? Will it be OK, or will she have issues with rubbing, etc?
Old 08-01-2012
sl33pyriceboi's Avatar
Re: p206/60r15 tires OK on stock 02 EX coupe?
P206/60r15 doesn't exist.
P205/60r16 will fit. But you wanna make sure you have at least a 6.5" wide rim. The stock Honda rims for our cars are 6" wide. That means you should run no larger than a 195.
Old 08-01-2012
If you run a p205 you will be pinching your tire. Which is not good.
Old 08-02-2012
QFT
QFT's Avatar
Thanks. I did mean 205 and did a bad copypasta
Old 08-02-2012
i would still recommend getting 195 instead of 205. there is no real benefit that is worth it if you are going to be putting it on a stock 6" (diameter) rim)
Paul Harsze
05-20-2015 11:37 AM
Pudnite
05-09-2015 07:51 PM
bo_red
04-23-2015 10:09 PM
GH04si
04-15-2015 08:13 PM
technosilver
11-14-2001 10:58 AM
Quick Reply: p206/60r15 tires OK on stock 02 EX coupe?
