Wheel touching brakes
Old 07-28-2011
Milkey's Avatar
Milkey will become famous soon enough
I recently purchased a set of used wheels, and to my dissapointment they are rubbing on my calipers / rear drum. I really like the wheels and don't want to get rid of them. Will a 5mm spacer do the trick to get the wheels off the brakes? I read that 5mm is the furthest you can go without extended lugs. If 5mm isn't enough, what would someone suggest? They are 195/55/R15. I searched around and couldn't find anything really relating to this, so if it's already been covered, I apologize.
Old 07-28-2011
Live for the Twisties
MindBomber's Avatar
Re: Wheel touching brakes
tire size is irrelevant, the off-set of the wheel is the issue.
You could get a set of 5mm spacers and that might solve the problem, it just depends how much clearance you need.
Old 07-28-2011
Received 1,440 Likes on 1,196 Posts
where are they rubbing? top, or sides?
Old 07-29-2011
sl33pyriceboi's Avatar
you an fit 14" rims without any problems i am curious why ur 15 rubs
Old 07-29-2011
Milkey's Avatar
Ya, I can't seem to figure it out. I guess the wheel itself just isn't wide enough. No one sells spacers around me and I don't wanna buy them online and be sol.
Old 07-29-2011
Whachya lookin at?
BlueEM2's Avatar
I'd buy them online and try them... Assuming they are not too expensive. If it's only rubbing 5mm should be plenty.
conspiracy90
06-07-2023 01:01 PM
GolNat
Suspension DIY
05-12-2022 06:49 AM
Misfit2613
Brakes
26
09-01-2018 05:02 PM
Thriftmaster
Vancouver
04-28-2015 06:02 AM
mugenca
04-16-2015 12:15 AM
Quick Reply: Wheel touching brakes
