overspray on brake discs
Rep Power: 0 overspray on brake discs
hey, i just painted my calipers and noticed about an inch of light overspray above and below the calipers on the disc, should i try and remove it with paint thinner etc. or will it just rub off as soon as i engage the brakes? thanks
Dr Krieger of Modification
Re: overspray on brake discs
i just let the brakes grind it off mine. my front discs always rust in the rain, but after driving they're back to silver, i don't think you'd have any problem if you just let the brakes eat the paint.
Live for the Twisties
Rep Power: 260 Re: overspray on brake discs
A tiny bit might be stuck to the pads, but it would burn right off after braking a couple times. Like mac said, rotors rust all the time and thats no issue.
it's not so much the heat as it is the friction that grinds paint off. it sounded like it was less then one layers worth of paint, im imagining he doesn't have a nice glossy coat over the brake serface, that would comprimise brake safety.
thaler4cuse
09-07-2015 08:25 PM
Josh 1973
09-07-2015 10:10 AM
hatch90
09-03-2015 08:45 AM
