what tire size would look good for 15" rota slips with nuespeed race springs
Rep Power: 0 what tire size would look good for 15" rota slips with nuespeed race springs
hi everybody i have a set of nuespeed race springs and i have a set of 15" rota slipstreams on my garage just sitting waiting for some tires to put on them. i want to know what tires would look better 195/50/15 or 195/60/60. can some please post a pic of their ride. soo i can decide and get tires and put it on the car
1 Post
Rep Power: 328 do u have any pixs of ur car with the race spring on? i wanna see how low they dropp and if the drop in front settles in with the drop in rear....
are u running on oem struts?
piiiixs =] for nice car =]
Rep Power: 247 i suggest 205/50/15. i think those rotas are 15x7 right? if they are 15x7 then i think you would need 205. imo i think 60 series would look way too fat. even with my size tire i am running now the 50 series looks fat. i say go 205/50/15.
I just burnt my tongue
im running 205/50/15 on my 99 si's...i love the wider tread cuz of the grip it gives me but the side wall is big enough so i get a decent ride out of it too...tires i recommend are Falken Azenis RT615 or if u wanna spend less than falken ziex 512 in 205/50/15...
Rep Power: 0 what would you guys go with for 16" rims? would you go with 205/50/16's or 215/50/16's? same drop springs and i want to fill up the gap as much as possible without rubbing. the 215's are .25 of an inch taller than stock tires while the 205's are .14 of an inch lower. i think their was an inch of a gap in the front and inch and a half gap in the rear with the stock tires on. what do you guys think, should i take a chance with the 215's?
Rep Power: 0 205/50/15 will lower your car even more, be aware of that.
The difference between 185/65/15 ride height and 205/60/15 ride height is -0.7 inches.
For later model civics, the difference in heights from 190/60/15 to 205/60/15 will be -0.53 inches.
These measurements relate to how much lower the center of your wheels will be, meaning the whole car will be that much lower. Hope you can afford the loss of clearance.
Touge
05-20-2015 10:53 PM
bo_red
04-23-2015 10:09 PM
