Bolt to remove drums
Slowest 7thgen in the GTA
1 Post
Rep Power: 261 Bolt to remove drums
My friend showed me a technique to remove the rear drums with two bolts.
Does anybody know what size bolt I need to remove these drums. I tried on my last oil change to remove the drums by pulling on them, and I could not take them off.
btw, yes the parking brake was off. I may be weak, but not that dumb..lol.
Thanks, Phu.
Thanks, Phu.
let the devil out
Rep Power: 363 I think they are 10mm bolts.. but I used a rubber mallet and hit the drums to pop them off due to rust etc.. works rather good
let the devil out
Originally Posted by PunkingCivic
you can use the bolts that hold the brake line to the body to back the drum off
1 Post
I need another number. Bolt size have 2 numbers. I don't know what they mean, but I know they have 2 numbers.
Anybody know for sure what bolt size I need???
1 Post
Sorry, I can't make a visual picture of what this looks like in my head.
Jap-Euro Fusion
Rep Power: 399 Clarified
The step thats often missed is RELEASE THE E-BRAKE. If you try to pull the drum with the e-brake on, it'll never come off.
Once the e-brake is off, you can probably just whack it with a mallet (a rubber one) and it should pop loose.
JDM-Jonathan David Martin- I own everybody
Rep Power: 0 The bolt I used to take them off was the bottom bolt for the heatshield on the header. (From my EX model). As long as a 12mm socket will fit the head of the bolt, it will work!
1 Post
Clarified
btw, I tried with a rubber mallet, and the e-brake was off.
I gave up after it didn't budge after 5 mins...lol. I'll try this bolt technique though.
Thanks again everyone.
Rep Power: 0 Thread
manfredww1
07-14-2015 10:24 AM
OptimisticWay
07-10-2015 04:31 PM
ballmich
07-09-2015 11:59 AM
