humming noise from left rear tire????
Rep Power: 0 humming noise from left rear tire????
my left rear tire just begain humming. I don't think that it is a wheel bearing the car is to new. Could it be a busted belt in the tire??? The tires are yokohama parada with around 5k on them. What else could it be???
Rep Power: 320 are you lowered? i had paradas on my 96 civic and on my current 02 civic. the slightest bit of negative camber causes them to wear unevenly. the noise only got worse so i switched to the toyo proxes 4's. the parada is a great tire but that tread pattern does not work well with negative camber.
Rep Power: 320 don't know why but that happened to me with two different sets of paradas on two different civics. i will never buy those tires again. i have a brand new set of 215/40-18's in my basement that i will never use because of that noise. they will probably be fine with correct camber. anyway, i couldn't be happier with my new toyos.
Pudnite
05-09-2015 07:51 PM
