rims+tires for stock 2002 Si
Rep Power: 0 rims+tires for stock 2002 Si
Can anyone recommend a rim size + tire size configuration that will work for my factory 2002 Si Civic? I have been shopping around and get many many different opinions from shops that seem like they have never upgraded rims on a car before. I have been toying with lowering the suspension and taking the reccomendations found throughout the site.....but fear that my luck will run out if I try something major....leaving me with my wheels up on blocks while I try to figure things out. I have never taken a bus and would rather not start now.
Derek.
Derek.
Still in the game...
Rep Power: 324 im thinking of two words, the first, one syllable and four letters. the second, four syllables and ten letters. it can be found at the bottom of the page where all the forums are listed. what am i thinking of?
Rep Power: 251 your bolt pattern is 4x100 i believe. 4 lugged. check out the tire calculator on this site under "quick links". their are so many tires/rims out their avaiable. you just need to research more on the net or visit more tuner wheel shops.
search this site and you'll see a lot to look into. goodluck and hope you dont get gypped in the future
Rep Power: 0 if you plan on lowering in at some point i would do one of these combo's and i do work at a shop that we do alot of wheels
15" with 205/55/15, 205/60/15
16" with 205/50/16
17" with 215/40/17 if you plan to lower if not then try 215/45/17
18" with 215/35/18 or 215/40/18
19" with 215/35/19
those are the most popular combos that i use on a civic, there are many other combos that are possible if you need any recommendations pm me and let me know what you are wanting and i will help you in the right direction
16" with 205/50/16
19" with 215/35/19
CarStuff
12-06-2020 12:52 PM
