195 vs 205 vs 215. whats your preference?
Ridin' Dirty!
im riding an ep3 on 205 size tires and was thinking about going to 215, but just thought i shouldnt write off the stock size 195 so quickly. any thoughts? which do you prefer?
Received 1,440 Likes
Rep Power: 338 Re: 195 vs 205 vs 215. whats your preference?
they are more expensive :P
not needed if you do not do autoX or similar competition.
better looks, though
Autocross Padawan
Rep Power: 187 Re: 195 vs 205 vs 215. whats your preference?
I plan on running 235's on 16x8's but they'll be for competition only. If you're running any kind of performance tire (RE01's, Azenis) then the extra width makes driving a lot of fun especially on aftermarket suspension. But yes, it is more expensive.
^Warranty voider
1 Post
Rep Power: 198 Re: 195 vs 205 vs 215. whats your preference?
A wider footprint also makes it more difficult to cut through snow (if it affects you) and can sometimes make it harder to evacuate water as a wider tire increases the surface area that has to move through the standing water. Wider tires also increase friction that, while increasing cornering grip slow you down in a straight line and increase rolling resistence. Everyone is on point, if it's grip and looks that you want, then damn the torpedoes and do as the hookers here on OBT do and stuff the widest rubber in there you can.
Autocross Padawan
Yeah increased rolling resistance is a good point. It can actually be quite a positive, particularly if you're putting down some decent power figures. Spinning tires through 3rd gear is no fun
^Warranty voider
1 Post
lol your absolutely right it isn't much fun at all. Like you guys eloquently stated in yalls previous posts you have to weigh performance and practicality.
1 Post
Rep Power: 328 Re: 195 vs 205 vs 215. whats your preference?
i run a 215/40/17 on falken azenis and love them. much more traction when i feel like hooning around the corners and on ramps...much improvement when running in the canyons.
i did do a trip to sema this past week and i only avg 33mpg...when i ran my stock steelies (195/60/15) i avg 37mpg
so yes, it does affect ur mpg quite a bit.
^Warranty voider
1 Post
^im bring this thread back after am onth because, ironically enough, it popped up in google when I had a question and it actually helped me. But I wanted to add something to your post that many people over look when they upgrade tires. Your speedo goes off when you upgrade tires, but keep in mind your odometer does too. So if you go to miata.net and use their tire calc, find out what % your tires are off by and add that to your mileage, I bet that is where most of your MPG went
1 Post
for example, if u put a 205width tire on a 7" rim, ur tires will be stretched a little resulting in an even smaller tire diameter (which the miata tire cal does not take into consideration)
it'll look like this: \_______/
where as if u get a 205width on a 6.5" rim, it'll look closer to this: |________|
\_______/
|______|
1 Post
i use to get 37-39 with 195/60/15
but my car is pretty orientated around handling. warped with falken azenis 615. sticky as hell, but the tire life is like 13k miles. not bad for a 200tredwear
1 Post
never really understood why people spend a **** ton of money on their suspension and then get some shitty tires...or anything that has higher than a 250 tredwear
me have other rims and tires still running stockies DD
09-26-2023 06:44 PM
BootyDo
06-21-2016 03:45 PM
curaze
09-22-2015 08:27 AM
