Powerslot rotor + HAWK pad combo *truehonda*
Rep Power: 0 Powerslot rotor + HAWK pad combo *truehonda*
http://truehonda.com/inventory.php?a...tdetail&id=489
i had my front rotor resurfaced 3 times and brakes pads replaced by big-o-tires. im standing at 50k miles. after every resurface (5-7k inbetween), the problem only comes back...vibrating/shaking steering wheel on highway speed braking. now im looking at the powerslot combo truehonda offers and would like to see what others think of it as far as daily driving goes?
im looking for a good replacement for the OEM rotors at a lower cost and better pads than the big-o brand i got in there now.
I like my commute
Rep Power: 253 Re: Powerslot rotor + HAWK pad combo *truehonda*
they're awesome.. I've had them for probably 6 months now and the braking is fantastic a lot of people will say that it just improves feel.. but when I put decent pressure on the brakes, the car really takes a nosedive
Jap-Euro Fusion
Rep Power: 399 Re: Powerslot rotor + HAWK pad combo *truehonda*
A rotor is a rotor. Slots and crap arent going to do anything at all, if anything they make rotors warp faster. I've been beating the living hell out of autozone rotors for years without ever having a problem. You might want to have the hubs checked for straightness. Either you're riding the brakes like a grandma, or something is helping those rotors along. Rotors every 5-7K is rediculous.
1 Post
Rep Power: 306 Re: Powerslot rotor + HAWK pad combo *truehonda*
uneven wear is normally caused by bad caliper or caliper hardware. Id have a thorough job done in cleaning the calipers, checking the slide pins for even, fluid movement. Id replace the rattle clips too and the new pads should always be lubricated before being installed. Either way, my power slot rotors have warped twice, my stock ones never warped at all. Im running powerslot rotors with PBR axxis ultimates. Trying to decide what my next setup will be. Autozone rotors might not warp, but heavy use has a tendancy to heat spot and crack them like crazy.
Rep Power: 0 Re: Powerslot rotor + HAWK pad combo *truehonda*
to break it down for brake maintanence (these are estimated mileage):
20k: new pads replaced with with big-o-tire's premium pads along with rotor resurface.
32k: vibration, resurfaced rotors
40k: same as above
50k (present): same as above but crazy vibrations
how much are autozone rotors? are they just as good or better than OEM?
when you say cleaning the calipers, do u mean like carb cleaner to get all that gunk out?
40k: same as above
1 Post
carb cleaner, brake clean, solution soak, whatever, 7thgen calipers seem to be pretty sensitive to that kind of ****. Even my gf's stock 03 sedan managed to get some pretty nasty wear on the pads because after a certain point the pistons werent coming out straight and it was because brake dust had accumulated on the caliper bracket and wasnt allowing the pads to move freely. jobber price on autozone rotors are like $12 a piece, big-o is probably charging you like $70 a pop, but regular price would probably be around 20-30 each. Some places will charge you more labor if you bring your own parts to make up for what they wont make in part mark up. So do it yourself or find a skilled person to do a quality brake job for you. and stop being so aggressive on your brakes, lol.
Junquito89
09-27-2015 10:22 PM
Bruce2
09-27-2015 08:45 PM
