tire/rim making weird sound
Old Dec 14, 2004
briem2jdm's Avatar
briem2jdm is an unknown quantity at this point
i need some help here when im driving every time one of my tire/rim rotates it makes a woom,woom sound could anyone tell me what the problem is do i have a bent rim or a bad tire i have 16 inch rims and it is really anoying sound and i want to get it fixed asap any help would be appreciated
Old Dec 14, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
I don't know what woom woom is. It sounds like a bad tire and its humming. If thats the case its the tire. If its more like a thwap, then you might want to make sure your lugnuts are torqued to spec.
Oh yeah... most people appreciate the use of punctuation. Makes it easier to read.
Old Dec 14, 2004
PunkingCivic's Avatar
I need TP for my bunghole
If it is a continous wooooooooooooooooooooooooooooooooooooooom sound as you drive it could be the tread of the tire. In time the noise will die down as the tires wear down.
Old Dec 14, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
what kind of tires are they? i had paradas and they made a very loud humming noise.
Old Dec 14, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
humming = unbalanced tires from the factory. Get new ones or return these. Unsafe to drive on.
Old Dec 16, 2004
HondaSales's Avatar
humming = caused by the parada tread pattern with negative camber, nothing to do with balance.
Old Dec 16, 2004
truehonda's Avatar
Not always, but since you know these tires, ill give you the benefit of the doubt
Old Dec 16, 2004
HondaSales's Avatar
i know its not always, it has just been my experience (x2) with the yokohama paradas. don't know why i got them the second time...never again.
mrohitredd
18
May 14, 2015 07:35 PM
dennis123
May 3, 2015 03:14 PM
SSMatey
Apr 13, 2015 06:09 PM
Ronin
Nov 17, 2001 09:46 PM
