Tire Pressure = 205/50/16???
Old Dec 7, 2003
hkyuppies's Avatar
hkyuppies is an unknown quantity at this point
What's the tire pressure of this 16" tire ?
My car is Civic Sedan
Old Dec 7, 2003
Mr.Modify's Avatar
i believe you should keep it inflated at , at least 35psi no more than 40
Old Dec 7, 2003
hkyuppies's Avatar
Factory Setting is 30psi for my 15" wheel,
have to increase so much (5 psi) for the 16"?!
Old Dec 7, 2003
Mr.Modify's Avatar
35 PSI won't hurt it...that's like minimum! Also doesn't the tire give you the air pressure stats on it? what kinda tires?
yea just stay in the range of 30-35!
Old Dec 7, 2003
Zzyzx's Avatar
Autocross Junky
run them at 30-32. No need to go any higher (Unless your Autocrossing or road racing). The tire pressure you should run is determined by vehicle weight. I've run my 205/40-17s at 32 for as long as I've owned them. note that if you run too much or too little pressure you will cause un even wear on the tire. Oh ya, that PSI rating on the side of the tire, thats the MAX pressure the tire is rated for, not what you should run them at.
Old Dec 7, 2003
reytito's Avatar
i keep them at 35
Old Dec 8, 2003
hkyuppies's Avatar
would 35PSI cause uneven wear on the tire?!
Old Dec 8, 2003
reytito's Avatar
no, it shouldn't
Old Dec 8, 2003
hkyuppies's Avatar
how's your gas mileage after using 16" Tire?!
It consumed me 20% more than before.....
Old Dec 8, 2003
reytito's Avatar
y?
Old Dec 9, 2003
hkyuppies's Avatar
18mm wider than 15" for each tire.........
I guess........
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
cukaracha
Jul 23, 2015 08:50 AM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
