00 si tires= 02 ex tires???
Old Jul 7, 2003
Reggie's Avatar
Reggie is an unknown quantity at this point
i wanna get some 00 si or 03 ex rims and i was wondering if i could use my stock 02 ex wheels and mount them on si or 03 ex rims?? would it fit??
Old Jul 7, 2003
666's Avatar
666
666 is an unknown quantity at this point
You mean take the tires off your 02 EX wheels and put them on the SI wheels correct? If so yes it will work, bolt pattern offset are all the same too.
But keep in mind the SI tires were a 55 series and the 02 EX are 65, so you could'nt leave the tires on the SI wheels and mount them on your EX, they will be too small in overall diameter.
Old Jul 8, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
The tires fit fine on the wheels. The only difference between the 195/55/15 tires off the 99-00 Civic Si wheels and 185/65/15 tires are only by .25" or so. Might make your odometer barely off but that's the only thing I can think of. The compound no the stock 99-00 Michelin tires are way better than the stock Firestones on your 02 EX wheels. Good luck with everything man
Old Jul 8, 2003
civicvtec1ps's Avatar
Search and Learn
yea it should work.
just get everything rebalanced
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
