Regular Maintenance Post Questions/Information about Regular Maintenance here
Timing belt & water pump on a timeline or just mileage based?
Old 04-21-2019
Pete6032's Avatar
Pete6032 is an unknown quantity at this point
Have a 2001. Did timing belt and water pump about 8 years ago at 100k. I only have 140k on the car now but the owners manual says to change every 7 years or 110,000 miles. Should I consider doing the pump and timing belt again?
Old 04-21-2019
Colin42's Avatar
Received 1,120 Likes on 935 Posts
Re: Timing belt & water pump on a timeline or just mileage based?
Yes, use OEM parts
Old 04-21-2019
Received 1,437 Likes on 1,193 Posts
no, you don't need to.
But rubber deteriorates over time.
Just be prepared, for if it snaps, you will need to do the valves. If damage great, it could include pistons among other things.
engines are interference, meaning pistons will literally kiss the valves bye-bye
Old 04-21-2019
Colin42's Avatar
I posted this a while ago
Originally Posted by Colin42
"But I haven't gone 100k miles yet, what do you mean my timing belt is due?"
Stolen from Reddit
Originally Posted by ezone
Wow. That's on borrowed time......but it'll be fine....until it isn't.
The moment it stops making noise is the moment is just got really expensive (assuming valve bender engine plus a tow truck fee)
Old 04-21-2019
Originally Posted by Pete6032
Did timing belt......... 8 years ago at 100k
Doesn't the manual clarify time/mileage with a line like "whichever occurs first"?
Your belt is already older than 7 years........
Rubber deteriorates over time, and you've been informed of what can happen to the engine if the belt fails...........
The ball is now in your court.
joea19701
01-21-2013 05:27 PM
mikey1
68
05-02-2011 07:46 PM
Tennessee Mike
09-28-2010 07:32 PM
flir
02-20-2008 08:12 AM
Notorious SI-G
08-05-2005 08:51 PM
Quick Reply: Timing belt & water pump on a timeline or just mileage based?
