Air Conditioning Post issues with air conditioning here
2005 Civic - AC not working...
Old Jun 2, 2021
jhomes551's Avatar
jhomes551 is an unknown quantity at this point
I tried all the usual for an A/C diagnosis.
Relay is good.
Clutch engages.
Pressure in lines.
System shows correct level of refrigerant.
Air is NOT cooling at all....
Am I down to just needing a new compressor??
Anyway to test a compressor without removing it?
Thanks in advance!
Old Jun 2, 2021
Re: 2005 Civic - AC not working...
check if radiator is not low in coolant.
if low, check if your coolant reservoir is not full (if it is full, read link below)
https://www.civicforums.com/forums/3...reference.html
Old Jun 2, 2021
Colin42's Avatar
What pressures are you seeing?
Old Jun 3, 2021
BrotatoChip's Avatar
Super Moderator
This. The pressure will tell you if the compressor is working.
davidezerron
May 30, 2015 02:45 PM
mwhonda
Oct 9, 2014 01:24 AM
Hutchoo
20
Jun 20, 2014 09:47 PM
Rufus
Apr 26, 2009 11:32 AM
mrb420
Jan 21, 2006 11:34 AM
