2001 EX compressor won’t kick on.
Rep Power: 0 2001 EX compressor won’t kick on.
So I payed $1000 for this 2001 EX sedan, and I’m just trying to chase down all the gremlins. The ac compressor doesn’t turn on at all. I ran a hot wire to the plug that comes from the compressor, and when I touch it to the positive battery terminal it clicks once, but doesn’t come on. Does it sound like I need to replace the whole compressor? Or could it be something simpler?
Re: 2001 EX compressor won’t kick on.
You try to turn on the AC but the compressor doesn't engage....... NEED to see if both radiator fans come on when you try to turn on the AC
You sent power to the compressor....while that's connected you need to push the AC clutch outer plate toward the pulley and see if it will stick
If that makes it stick---How wide is the air gap on the compressor clutch
Does it look like half of a millimeter ? Does it look like 2 millimeters or more?
If that did NOT make it stick, use ohm meter to figure out if the thermal protector is open or if the clutch coil is open
Rep Power: 0 Re: 2001 EX compressor won’t kick on.
Thank you so much for the quick reply! Ok, so I’m just learning how to work on cars and have never messed with ac before. Which part of it is the clutch? I need to take off wheel and shroud to access it right?
Watch this video as it helped me get my A/C working again for cheap. You can skip to halfway to get to the part of removing a shim from the compressor clutch shaft to close the gap between the clutch magnet plate and the compressor.
IF the problem is too much air gap. OP needs to be aware there are a lot of other possible reasons an AC system might stop working besides that.
Ggp9909
06-05-2016 09:28 PM
hotrod_714
05-17-2014 04:50 PM
amatias
18
09-04-2011 10:12 PM
Wykkid_darkness
03-26-2011 05:33 PM
