car AUX problem - very complicated
Rep Power: 0 car AUX problem - very complicated
Hi everyone,
I am owning a civic 2008 coupe ex-l with the navigation system; recently I ran into a problem of AUX. At first, the port seems to not working since there was no AUX option when pushing the audio button, I immediately swap a new AUX port. The problem was solved, but then for a few months after that I notice sometimes the song just only play background music with very low vocal, I switched to radio and XM, and the sound back to normal. If I wiggle the 3.5mm jack then it worked fine again, but only for a while then it happened again. So I thought it could be due to cheap aux port, then I purchased the original part and swapped in, it worked immediately for like 5 days and backed to playing background music only. Again this only happens in AUX mode, with radio or XM everything seems to work fine.
I googled the problem but nothing came up beside the port itself. Have anyone seen this problem before? I think it could be the harness cable inside, if so does anyone know how much it costs to buy the replacement? and what does it called, since I google but only for aftermarket stereo popped up.
Please help, thank you
Prelude Owner
Re: car AUX problem - very complicated
Did you try a new AUX cable? I didn't see that mentioned. Might be the connection to the head unit.
Just put in a Bluetooth system and be done with those pesky cords!
I have this one and it works great.
https://www.usaspec.com/p-315-bt45-hon3.aspx
https://www.amazon.com/USA-BT45-HON3-Bluetooth-Select-2003-2014/dp/B00NMXMUW8/ref=asc_df_B00NMXMUW8/?tag=hyprod-
20&linkCode=df0&hvadid=312070784062&hvpos=1o2&hvne tw=g&hvrand=13562456991438323527&hvpone=&hvptwo=&h vqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021706 &hvtargid=pla-492941087433&psc=1
PAC Audio is another option.
https://pac-audio.com/?fc=module&mod...mp-sbv-submit=
Rep Power: 0 Re: car AUX problem - very complicated
Yes I tried to replace the AUX cable in the beginning. My friend gave me the high quality Monster cable but problem was still there, that also means the problem does not lie in the cable
Hi everyone,
Received 1,144 Likes
Rep Power: 485 Re: car AUX problem - very complicated
my understanding was the aux port on the 8thgen was absolute crap. My ex's car had the same problem, and I hacked it up and turned it into an aux port when her godfather gave her an in-dash navi double din radio he was gifted by a customer of his.
hey i think i have the same problem. three months ago i was driving down to FL from PA in my 08 civic with NAV, the AUX audio was making this weird whirling noise whenever i press on the gas to drive. it sometimes would go away or come back whenever i hit a bump in the road. when i have a FM transmitter on instead of the aux the problem wasn’t there. or with the radio or anything that isn’t AUX. i’m wondering if you ever got it fixed. or our problems are different.
also you know where the passenger airbag light is? whenever i press my palm to the light and apply pressure it would go away. weirdly. but the pressure has to be applied for it to sound normal. this is with the six. since the fm transmitter doesn’t work anymore.
Hi I’m new to the forum and just noticed that my 2008 civic all of a sudden lost the AUX option that showed up on the display. Wondering if this could mean that the actual port needs to be replaced. Can anyone confirm this?
Tino
Tino
Hi everyone,
Received 1,121 Likes
Rep Power: 190 Re: car AUX problem - very complicated
See how much a decent deck and dash kit is from Crutchfield is and then make your decision based off that. I personally only use Bluetooth for calls. I have my iPod plugged into the usb of my deck
There is a quick fix for this . It will require soldering. I saw the fix on you tube. In essence when you insert anything into the aux port the normal operation is for the radio to auto detect and switch to the aux mode. The fix removes this auto feature so if you plug anything there you will manually have to select the aux mode by pressing the aux button.
I tried that fix on my ex's 08 and it didn't work. Her godfather gave her an in-dash double din GPS head unit anyways, so I gutted the OEM aux port and made it into a USB port to connect to the rear USB port of the head unit
The following users liked this post:
Colin42 (10-06-2020)
Prelude Owner
Yeah I’d price a head unit and see how much it will run you. Bluetooth is usually not that much more and even Bluetooth ones typically have AUX and or USB. Both my cars have BT calling but only one has BT music streaming, the other is AUX. I do enjoy having everything BT so I’d spring for a fully BT unit.
I just bought the 2006 Civic Ex, I see the aux input, I just don't see where I can select it; there is no physical button nor anything on the navigation system interface. Any idea how can I select the aux input?
Auxhead
09-07-2018 06:52 PM
