Egr code and coolant in port.
Old 09-24-2018
310civicEX's Avatar
310civicEX is an unknown quantity at this point
Could the coolant in the egr ports be from the install. ..or leak? I just drove the car 850 miles and it had a pending p0401..I pull egr and see some coolant in the port
Old 09-24-2018
Slumpertcivic's Avatar
Re: Egr code and coolant in port.
I would expect if some coolant was somehow there from instal, it would have evaporated away in minutes when engine was warmed up.
Old 09-24-2018
Originally Posted by 310civicEX
be from the install
From WHAT install?
When? What was done?
Condensation (plain water, clean or sooty) in the port might be normal if the engine is not hot.
Can you PROVE it's antifreeze before wasting a bunch of time and energy on it?
Old 09-24-2018
310civicEX's Avatar
The liquid in the port is green like the coolant. But the coolant system doesn't apear to be losing anything. Drove through stop and go traffic in phoenix and never got hot.
I know it's not related but is there a good way to clean the egr ports? Without pulling intake off?
Old 09-24-2018
Again, WHAT install?
Old 09-24-2018
310civicEX's Avatar
The egr housing piece was recently installed..
Old 09-24-2018
There's antifreeze all around that housing, so there's lots of chances for coolant to enter the wrong area..... cracked housing or leak in the gasket area comes to mind
Was the housing brand new?
Fresh new steel gasket installed?
Torqued properly?
I'm inclined to apply sealant to the gasket around any areas that have coolant
Old 09-24-2018
If the passages have become clogged, it's expected to clog in the areas nearest the intake ports, which means pulling the intake manifold out.
That's not the only possible cause of P0401 though. Wrong intake gasket will cause the code.
EGR valve stuck shut may cause it
Old 09-25-2018
310civicEX's Avatar
I got new gaskets I'm gonna pull manifold off and clean egr ports..
Old 09-26-2018
310civicEX's Avatar
Pulled intake manifold off..all kids of black sludge in all the intake ports on the head.. the plastic intake was also coated with black sludge..same as thermostat housing.
Old 09-26-2018
Pulled intake manifold off..all kids of black sludge in all the intake ports on the head...
That should all just be carbon, because it IS exhaust that flows through the EGR passages.
Old 09-27-2018
310civicEX's Avatar
Is it bad to use compressed air to blow the egr ports out with manifold off blowing from manifold side blowing towards the thermo housing?
also.. the gasket that was on my car had ZERO egr port holes.. is that like a ricer thing or ?
Old 09-27-2018
Colin42's Avatar
Received 1,120 Likes on 935 Posts
well you need to fix that, someone put the wrong gasket in at some point
Old 09-27-2018
310civicEX's Avatar
Between the throttle body seal...intake port seals and metal gasket for egr plate..what needs sealanr?
Old 09-28-2018
Not ricer at all.
It's just a wrong gasket, simple mistake.
Platano3porpeso
09-15-2017 11:18 AM
cdmx
03-12-2003 11:28 PM
Roosbok
06-17-2002 01:34 AM
gqsang
04-16-2002 12:31 PM
Pongster
01-18-2002 09:30 PM
Quick Reply: Egr code and coolant in port.
