Engine cranks in any gear? - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 1 Week Ago   #1
D17VTECPOWER's Avatar
D17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really niceD17VTECPOWER is just really nice
So this first started about a year ago with the engine not cranking in park at random times, but cranking in neutral. When it wouldn't crank in park, the gear indicator light on the dash wouldn't be on at all. This would only happen every couple of weeks. But after a couple months of this not happening, I noticed that the engine will consistently start in any gear. The indicator light on the dash works correctly, but it starts in any gear now. I don't think that these two issues are related, but I have no way of knowing. Any ideas what could cause this? I don't particularly care if it cranks in any gear, but I don't want to ignore this problem if it could damage something else or cause another problem. Thanks
D17VTECPOWER is offline   Reply With Quote
Old 1 Week Ago   #2
Allow me to explain through interpretive dance
Re: Engine cranks in any gear?
Follow and diagnose according to a correct wiring diagram for answers.
ezone is offline   Reply With Quote
Old 1 Week Ago   #3
Quote:
I have a wiring diagram for the starter. My best guess is that the starter cut relay is stuck closed, but I'll have to find that relay and test it.
Old 1 Week Ago   #4
It's in the dash fusebox.
Has that relay been bypassed?
Old 1 Week Ago   #5
Thanks. I'll test that relay and report back. And no it has not been bypassed. I didn't even know that it was there until I looked at the wiring diagram.
Old 1 Week Ago   #6
I can find out a whole lot of answers by probing a simple test light in the relay socket.
Old 1 Week Ago   #7
I'm sure you can. However, the relays in the fusebox under the dash aren't exactly easy to get to. In my opinion, it would be easier to start with removing the relay and testing it outside the car than to do testing from the socket.
Old 1 Week Ago   #8
Quote:
Disagree, regardless of difficulty. You aren't likely to find the relay stuck on, and if it were stuck on then trying to pull it out of the box would probably make it unstick and all your evidence would disappear in an instant.
I don't think I've ever needed to test a relay out of circuit. I've always been able to judge by evaluating the 4 or 5 terminals in a typical simple relay socket.
Be glad it's not a German car. LOL
Old 1 Week Ago   #9
But wouldn't you need to remove the relay to do your testing from the socket anyway?
Old 1 Week Ago   #10
Okay so I removed the relay from the socket and it still cranks in any gear. What does this mean? Short in the load side?
Old 1 Week Ago   #11
Yes, but that doesn't matter if you KNOW what you should find when testing in the socket.
Know. Evaluate. Judge. Deduce.
Old 1 Week Ago   #12
Good point. I'm late and it's tired. :yawn:
Old 1 Week Ago   #13
you pulled the wrong relay?
Or its bypassed somewhere
Old 1 Week Ago   #14
Effed up range switch?
Old 1 Week Ago   #15
I don't think so. All the indicator lights on the dash work correctly.
Old 1 Week Ago   #16
I pulled RY1 on this diagram: http://www.skidmore.edu/~pdwyer/portfolio/e/udfrb.htm
Old 1 Week Ago   #17
You pulled the relay and you have a wire diagram.. Test, dont guess.
It's not the relay.
Old 1 Week Ago   #18
It's not the relay.
It can't be the relay since it still cranks without it installed. Something must be shorted. I'm too tired to go any farther with this tonight though since it's almost midnight here. Thanks for your help.
Old 6 Days Ago   #19
Would it be a bad idea to ignore this issue?
Old 6 Days Ago   #20
Depends®
Old 5 Days Ago   #21
Depends®
Basically, I'm asking if ignoring this issue will strand me, damage something, burn my car down, or do something else nasty. I WILL NOT start it in gear, so no need to worry about that. Even if I did (which I won't), I always use the parking brake, so it's not going anywhere.
Old 5 Days Ago   #22
What do YOU think?
Old 5 Days Ago   #23
What do YOU think?
I think it's fine to ignore.
Thread Thread Starter Honda Civic Forum Replies Last Post
02 civic lx, engine cranks but doesn't turn over. Please help iceman_1227 Mechanical Problems/Vehicle Issues and Fix-it Forum 7 08-27-2011 10:54 PM
Engine Cranks - No spark or fuel... ideas? vcantrell Mechanical Problems/Vehicle Issues and Fix-it Forum 1 07-30-2010 12:13 PM
01 EX Engine cranks but won't start. andymanv Mechanical Problems/Vehicle Issues and Fix-it Forum 23 02-19-2007 02:55 PM
New Distributor - Now Long Cranks and Engine Light wfernley General Honda Civic Forum Archive. 8 09-27-2004 12:02 AM
Engine Noise in 1st Gear - 2nd Gear Acceleration... ASIANPRIDE Mechanical Problems/Vehicle Issues and Fix-it Forum 0 09-24-2004 02:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright © 2017 CivicForums.com
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
