Overflow tank full
#31
Re: Overflow tank full
Everything got dissembled and head is at the machine shop. There is some warpage on the intake side of the head so they are repairing this as I type this. will be replacing the water pump and tensioner today and hopefully head is done soon. For everyone having a hard time removing the crank pulley, I suggest investing in the Milwaukee m18 impact gun. Mine has a reverse trq of 1400ft-trq and made that removal a breeze without the need for the honda tool to even hold the pulley
#33
#34
Head came from the machine shop. Cleaned and ready for install.
Wrapped up the install today.valve cover went on as well. Everything was at TDC, checked it about 6x before it got closed up. Just need to install intake, coolant and bleed and keep my fingers crossed it starts up
#37
Rather than writing miles and date on the timing belt (where it will never be seen AND wear away the writing), write it on the upper timing cover where it can be seen clearly and easily......I use paint, touch up or paint pen
#38
Yea I wrote it on the outside cover and also wrote it in the owners manual book just incase
#39
50 mile update is good. Car started up on the first try, idled smooth for the 2 min I let it idle. Bled the coolant and all. Noticed the car runs alot smoother after the headgasket got changed.no cels or anything came on.will see how the coolant overflow looks after a few days. Thank you all who contributed and gave me advice.
#41
UPDATE: car has not overheated or had any issues since the head gasket was replaced. january 9th i got rear ended and car was a total loss . on the bright side i got a very nice check from the insurance company, and ended up buying another 05 civic coupe.drove it for about a week and as you may have guessed this one is starting to over heat as well. Heat is delayed and overflow tank is fills up. Also the inside of the overflow coolant tank has a blackish tint to the coolant. Looks like we will be doing another headgasket replacement smh!
#42
It’s a very rare day when someone sells a perfectly good 6+ year old car.
Besides taking the intake off “which I don’t think ever gets easier”, you will find every other part of the repair a lot simpler now that you have done it once already.
#43
Yea that's my thought as well.only real problem with this civic is it has alot more rust then my old one and I have a feeling it might give me issues especially the exhaust manifold bolts.on the bright side they are infront so alot easier to actually see them 😅
woodly1069
11-26-2013 01:22 PM
Matt_75
11-18-2012 10:10 AM
gouncheels1
05-27-2012 12:51 PM
cja3455
12-12-2011 06:49 AM
streetglower
01-13-2006 09:04 AM
