Slow Accelerstion Civic 2005 EX Sedan
Rep Power: 0 Slow Accelerstion Civic 2005 EX Sedan
My car, Honda Civic 2005 EX, is taking long time to accelerate, for last few days. Car ,literally, struggles when it moves from a stop—in a stop sign or red signal. I can also feel the shake it when gear shifts.
I changed oil, cleaned fuel system and rotated tire but no sign of improvement.
What may be the root cause of this problem?
Re: Slow Accelerstion Civic 2005 EX Sedan
Check engine light on? Fault codes are ______ ?
Codes are a starting point
Low engine power? Misfire?
Transmission issue? Stays stuck in 3rd instead of shifting to 1st at a stop?
To rule out clogged cat, you could loosen the exhaust header bolts two turns and see if that makes a quick improvement besides the noise... Some people unscrew the O2 sensor but as costly as those are your better off not touching it unless you have too.
Also consider pulling air filter cover off and giving it a quick trip to see if that made a difference.
Honda-
12-10-2017 06:18 PM
RustyShackle
12-19-2016 07:16 AM
dnmacdon
07-19-2016 05:41 PM
erikmontana
51
01-16-2005 09:10 PM
