SRS on, no error?
Rep Power: 0 SRS on, no error?
Hi
I reset the SRS light on my 01 Civic using the paper clip method to the yellow plug under the dash.
Seconds later the light comes back on and stays on.
The SRS did not blink then, or when the key is turned, b4 ignition.
Would that imply 1-1 from the DTC list i came across?
Received 1,144 Likes
Rep Power: 485 Re: SRS on, no error?
nope. You have to jump pins 4 and 9 on the obd port to read codes
follow this thread (and the linked thread) to figure out what's making your srs light illuminate
https://www.civicforums.com/forums/1...ding-them.html
I'm willing to bet it's driver side seatbelt.
Received 1,440 Likes
Rep Power: 338 Re: SRS on, no error?
but code readers are getting quite cheap to not to use them, or to stop at an auto parts shop and ask to have the codes being read. If you choose to buy one, be sure that it will read SRS codes.
Rep Power: 0 Re: SRS on, no error?
Thanks,
Is this the correct approach:
Car off,
Jump pins 4 & 9 as shown in the diagram,
Car put into on position, b4 ignition start.
Blinking SRS would appear giving me the error code?
I called one of the shops, they only read ODB2
Car off,
2001 is OBDII
OBD 1 is up to 1995
(at the least, in US - where is the car from?)
OBD 1 is up to 1995
You are 100% correct.
9-3 Drivers Side Seatbelt Buckle Switch
I read people paid hundreds at the dealer, $400 was the latest thread i read which i can't justify paying.
Thoughts on purchasing a new seatbelt buckle and installing myself? Seems fairly easy.
OBD2 only refers to On Board Diagnostics for the powertrain (engine and transmissions)
SRS has nothing to do with OBD2, other than its electronically accessed with a scanner via the same data link connector (OBD2 diagnostic port).
Many low cost consumer grade code readers and scanners are available that are capable of reading codes from systems like SRS and ABS.
Hell, I just got a batch of Harbor Freight coupons in my email advertising some new scanner they carry that does all 3 of those.
Buckle replacement, easy IMO. Usually have to get the seat off the floor, but it's not hard.
edit: https://www.ebay.com/itm/HONDA-CIVIC...5VHD5a&vxp=mtr
$45 shipped for a black one. Saw a grey one for the same price
Would this be covered under the lifetime seatbelt warranty?
My 03 ACURA EL got this code 5 years ago and the dealer paid for the part and I paid the labour. We don't have the lifetime warranty in Canada.
I am curious which part you purchase. if you have a link to ebay that will be ideal
thank you!
A mechanical fault with the buckle (the part attached to the seat) it should be covered under Hondas eternal seat belt warranty. As long as the buckle won't click and lock the seat belt securely a dealer will probably take care of it at no cost to you.
See your owners manual and original warranty info for more details
If your handy, take it out, take it apart, clean it thoughly with electrical contact cleaner (esp the little micro switch inside) and use a liberal amount of spray graphite to relubricate the mechanism.
If you end up ordering one from eBay or taking out from a junkyard, you could still do the above steps..
But if you can get the dealer to do it for free..
matman
08-07-2019 06:15 AM
mikey1
09-20-2018 11:13 PM
Kennykenny
12-05-2013 09:43 AM
2k1_Toaster
27
08-06-2012 08:50 PM
NHKen
10-25-2010 12:27 PM
