My Engine Light Comes on and off
Old 01-11-2018
Ian Grabowski's Avatar
Ian Grabowski is an unknown quantity at this point
my engine light will come off when its cold and sits for more than a day ,sometimes, or it'll stay on until it comes off. I have a code reader and its a cylinder 3 misfire, I've replaced the spark plugs and have coil packs coming in today to you have any other ideas?
Old 01-11-2018
Wankenstein's Avatar
Re: My Engine Light Comes on and off
Does the CEL blink multiple times?
What is the exact code please?
If a coil is suspected just swap with another one next to it..if, say cylinder 3 is faulty and is swapped with cylinder four (not faulty)..then cylinder four will throw a misfire code and cylinder three won't. This isolates the issue and reduces unwanted expense if coil(s) are working properly. The same can be done by swapping spark plugs.
Use a piece of PVC tubing, long screwdriver or autostethoscope and place it against cylinder 3's fuel injector while the engine is idling. You should hear it firing (pulse/ticking sound). If you don't hear it the inector isn't firing and needs to be replaced. If it is firing it doesn't mean it's injecting the right amount of fuel, spray pattern or injecting fuel at all. So, lack of or absence of fuel in that cylinder could be the cause of misfire. Can swap the fuel injectors to test.
Do a compression test.
Read: http://troubleshootmyvehicle.com/hon...el-injectors-2
Old 01-11-2018
Slumpertcivic's Avatar
Check your coolant level..#3 misfire might also be early signs of a head gasket failure
Old 01-13-2018
It doesn't blink and i already bought the four injectors just to replace them on the car they look old and ill try the injector and ill look at my coolant Thank you tho this really helps
Old 01-13-2018
I installed them and it seems to be running smoother but the engine light is still. Would it shut off automatically or do i have to drive it a certain number of miles
Old 01-13-2018
Disconnect battery for a few minutes to erase engine codes
Make sure you have your radio unlock code first!
Old 01-16-2018
Unhappy Re: My Engine Light Comes on and off
Hey so ive driven my car for a while after it shutting off for a while and now its blinks is that bad or no
Old 01-16-2018
Explain this in greater detail?
Old 01-17-2018
When the ECU decides something is completely whack it will flash the MIL..
Crank position and camshaft sensors reading las if two cylinders are dead is the kind of stuff needed to cause a flashing MIL.
Really should not drive at all in flashing mode, between too much raw fuel going into catalytic converter which can lead to burnout or actual fire, too to much unbalanced vibrations causing bearing issues it’s time to tow it if you care about it.
Old 01-17-2018
For about a week it was off for about 200 miles or so and i started to drive the car again yesterday and the engine light was on blinking but its only when im at a complete stop and sitting for a minute
Old 01-17-2018
Flashing CEL while running means misfire codes.
Read codes to figure out which cylinders are affected.
Fix the misfire.
Compression test?
Old 01-18-2018
Fix the misfire.
Compression test?
Imma do one today and the code is cylinder 3 misfire
Old 01-21-2018
Fix the misfire.
Compression test?
So i did a compression test and the cylinder thats misfiring is running at 100 to 110 and the rest were at about 150 to 160 i was told that i need to adjust my valves or get new rings but rings are a bitch to do
Old 01-21-2018
On the low cylinder did you try adding a bit of oil in the spark plug hole to see if compression goes back up to 150range?
Seems our engine is famous for losing a lot of compression if the cylinder gets flooded with gas.
Old 01-21-2018
Valve adjustment is one of the first steps. Tight valves can cause low compression......and if ignored too long, tight valves can burn.
Adjust valve lash to specs
Do compression test again, see if compression comes up in the low cylinder
If no improvement, then a cylinder leakdown test is used to help locate the cause of compression loss.
Wet test is used for checking compression rings, but it can be misleading sometimes.
A burned valve causing low compression is much more likely than failed compression rings, but stuck oil control rings are just about expected at high mileage.
Also, I expect to see 180+ psi out of these engines using my testers and methods:
-All plugs removed,
-throttle propped wide open
-battery charger connected so battery stays up throughout the testing
-place gauge where I can see it while cranking
-Crank it until the gauge stops climbing, then keep on cranking for several more hits just to make sure the gauge has reached its absolute maximum
devil4life409
04-17-2020 06:25 AM
karenpoop
05-07-2009 05:33 PM
devil4life409
11-09-2008 04:21 PM
jsbush
08-16-2003 01:23 PM
dhuong23
02-02-2003 03:04 PM
Quick Reply: My Engine Light Comes on and off
