Oil Leak Top of Motor But Not Cylinder Head Plug
Rep Power: 0 Oil Leak Top of Motor But Not Cylinder Head Plug
I have an 03 ex coupe 5M 138k miles with a nasty oil leak. I mean really nasty(a little over 3 quarts in 2 weeks). It only really leaks when running and up to temp, but it still drips cold. I already replaced the cylinder head plug and the EGR valve gasket which stopped one leak, but presented another. I've gone through a myriad of forums as to not have to post my own thread, but I've only found people talking of the cylinder head plug. The oil looks to be coming from the very top of the transmission, and runs down along the seam where the motor and tranny meet. It isn't leaking from the bottom of that seam so I'm hesitant to call it as a rear main seal. If anyone has any suggestions or ways of better diagnosing the issue it would be much appreciated.
Re: Oil Leak Top of Motor But Not Cylinder Head Plug
Clean the engine off well with Gunk engine cleaner and old rags. Can sprinkle baby powder all over it too to inspect for leaks. Run engine if necessary to help find leaks. Start inspecting form top of engine downwards. Possible leaks in the area you described are:
1) Valve cover gasket
2) Cylinder head end cap (you replaced)
3) Rear main seal
4) Oil pan gasket
5) Vtec gasket (if EX or SI model)
3) Rear main seal
4) Oil pan gasket
VTEC valve leak, lower and upper gaskets?
(search this forum for part number of the upper gasket your dealer says does not exist)
if its not the end cap, could be the seal between engine and tranny,
how old is your PCV valve?
a stuck old PCV valve with blow seals and gaskets in no time
Rep Power: 0 Re: Oil Leak Top of Motor But Not Cylinder Head Plug
3) Rear main seal
4) Oil pan gasket
3) Rear main seal
4) Oil pan gasket
I would assume the PCV is as old as the car itself. I just bought the car a couple weeks ago for $750 bucks. It was so cheap because of the leaking. Im going to try and change every seal I can without ripping the engine apart..
Im having a lot of trouble finding the vtec upper and lower gaskets together. If I look it up it seems that there they come in sets but those 2 part numbers arent together. It looks like I have to buy the separately.. Does anyone know of a website where I can buy them together??
On another post I found the two part numbers
Filter(upper): 15825-P2M-005
Lower: 36172-P08-015
Are these the correct numbers?
No they do not come in sets.
Did you find a post I made, with the part numbers?
If you can't figure it out, link the post so I can look.
Its a post you made, so I will assume its correct. Ill call up my local dealer tomorrow to see if they have them.
Found my notes at work
The lower gasket (filter) between the VTEC valve and the head is found in the parts catalog easily.
The Upper gasket for the solenoid is the one the dealership will not find in the parts catalog.
Honda # 36172-P08-015
There's a torque spec to the Vtec solenoid bolts. If it still leaks after torquing it down (or by feel) then you may need to apply Hondabond to the gasket..just avoid getting it on the screen. Definitely try it without a sealant first though. The 7th gen Vtec solenoids are beefier than the 6th gens I'm used to working on so maybe they don't warp like 6th gens can (or seem to).
You do NOT want any chance of stray RTV getting into any oil passages.
I've had two 6th gens that wouldn't seal without RTV..I tried new gaskets without RTV on both first but still leaked. Carefully applied a thin coat of hondabond to gasket and housing perimeter without getting on the screen and both sealed and worked fine since: 30k+ miles. I only applied it to the larger solenoid (snowman) gasket and not the smaller gasket that you posted a pic of. If OP considers using RTV he does so at his own risk. Hopefully, it will seal without it.
