2001 honda civic lx jumper on wires.
Rep Power: 0 2001 honda civic lx jumper on wires.
i recently just bought a civic sedan for a commuter. i found a jumper on a set of relays under the glove box. if it comes off the car will not start. i assumed it was the relays so replaced them both no change. when the car is running it runs very rough. when you accelerate it will sputter and die if you go above 1/4 throttle. if at idle and you turn the ac on it will try to die. if you can get it above a certain RPM it will seem to clear out but very little. I've been told its the ECM but would like confirm that if it is or looking for any help it would greatly be appreciated.
