Small engine oil leak
Rep Power: 0 Small engine oil leak
I just bought a 2007 Honda Civic LX and when I brought it home I noticed a few drops of oil on the ground near the front of the car. There wasn't much that leaked but it did worry me. Any information on what it could be and if I should be worried or not would be greatly appreciated. Also would like to know prices of common repair problems.
Rep Power: 125 Re: Small engine oil leak
Depends what is above the drops. Could be lots of things. Definitely do not put off finding out the cause. Take it to a reputable shop if you can see where its coming from.
Rep Power: 0 Re: Small engine oil leak
It is a little low. I don't know enough to reliably say where but it is around the front passenger side and only drips a little bit after I drive.
What did your mechanic say he found leaking during the prepurchase inspection?
You DID have a prepurchase inspection done, didn't you?
Slide under the car and seee what's leaking
Civicgal17
11-11-2015 03:34 PM
shriketheavatar
10-20-2015 08:31 PM
