Possible head gasket repair scheme????
Rep Power: 0 Possible head gasket repair scheme????
Hello Everyone,
I need your help.
I recently paid for a head gasket repair. Since then, I have had to take it back a few times because I was still experiencing overheat problems.
First time, it was a leaking hose (service covered under warranty).
Second time they installed a cooling fan switch.
They claimed they could not find a leak and were pretty sure the fan wasn't turning on enough [service NOT covered under warranty but they decided to wait for me to try out the car first for a little time to see that it was indeed the right fix and then I would pay for the service (which by the way was NOT actually officially authorized by me, meaning they went ahead and did the repair without my consent).
Not long after that which brings us to now, I had ANOTHER overheat condition.
Just took it to the mechanic shop again and they are now claiming they have found a leak and it is indeed coming from the engine. I was told they would have to send the cylinder block and head gasket back to the machining shop in order to find out if something is defective.
BUT, I was told, MORE THAN LIKELY, it will be a CRACKED ENGINE BLOCK (WHICH IS NOT COVERED UNDER WARRANTY)....
....My conclusion is this: THEY ARE HUSTLING ME.
Either the block is not damaged and they are trying to convince me it is because you don't get to check a repair like that to verify the job was done, or the block is damaged in which case they lied when at the outset of the head gasket repair they claimed the engine block needed no repair.
A third possibility is that from the time they installed the cooling fan switch to the time the car overheated again (TWO WEEKS) the engine block did actually suffer extensive enough damage that it now needs repair. Is this possible???
What do you guys think? Am I being hustled? Has anyone ever gone through something like this before? If they say it is the engine block do I have legal recourse?
ANYONE'S help is greatly appreciated.
I need your help.
Re: Possible head gasket repair scheme????
Wait, what year is your car?
There is a problem with engine blocks cracking, and there was an extended warranty placed on it.
https://www.civicforums.com/forums/1...-cracking.html
Furthermore, please only make one topic.
Double posting only makes for confusion, as there are going to be multiple answers in each forum.
(I dunno what a mod should do here, this post is in 8th & 9th gen, but the other post here:
https://www.civicforums.com/forums/2...ir-scheme.html
Is under 7th gen...guess we need to wait and find out what year the vehicle is)
Rep Power: 0 Re: Possible head gasket repair scheme????
I apologize for posting it so much. I just really need help and I just posted wherever I felt it was even slightly relevant.
Alright well, the extended warranty I posted does NOT apply to your car then.
Seeing as how you car is 7th gen, try not to respond to this topic any further, as it will either be deleted, or merged with the other topic in the 7th gen section.
Watch there for any answers, and if I were you I'd go an edit it and say what year and model your car is.
Good luck, hope you get some insight into your problem.
I have seen cars with "replaced" clutch too
Hello Everyone,
I need your help.
I need your help.
7thgensurvivor
38
08-29-2015 11:50 AM
jdawgzcivic
06-30-2015 06:35 PM
Tim1959
06-03-2015 08:15 PM
HondaHomer
05-14-2015 12:24 PM
