2002 Civic Ball Joints again
Old 06-22-2015
mapdog's Avatar
mapdog will become famous soon enough
I just replaced both front ball joints about 6 months ago. I noticed over the weekend that the driver's side rubber is completely destroyed. What could have caused this to happen?
Old 06-22-2015
mikey1's Avatar
Re: 2002 Civic Ball Joints again
i hate to even ask......what brand are they?
Old 06-22-2015
mapdog's Avatar
Whatever brand they sell at Advance Auto Parts. I'm not sure I saw a specific brand name on the box.
The Advance website says they are "Driveworks."
Old 06-22-2015
Prelude Owner
GolNat's Avatar
Get some Moog ones. They have nice thick rubber boots that will last.
Old 06-22-2015
mapdog's Avatar
Wow. All this work because of cheepo balljoints? The thing is they are supposedly lifetime warranty.
Old 06-22-2015
mikey1's Avatar
and this did not concern you?
Old 06-22-2015
mapdog's Avatar
No because it said lifetime warranty right on the receipt. They are Driveworks.
Old 06-22-2015
mapdog's Avatar
On the Advance website the Moog ball joint is available for 2x the cost but it had a bunch of 1 star reviews. I see now that it was because of zerk fitting on ABS applications.
Old 06-22-2015
mikey1's Avatar
what rating does yours have?
Old 06-22-2015
mapdog's Avatar
5 stars
Old 06-22-2015
mikey1's Avatar
okay.....so use the lifetime warranty and return them for new ones
problem solved?
Old 06-22-2015
mapdog's Avatar
problem solved?
Thanks, you've been a great help.
Old 06-22-2015
mikey1's Avatar
what do u want me to say?
you bought cheap aftermarket parts,
so you now have two options.....use your lifetime warranty and replace your ball joints every 6 - 12 months, or purchase quality ball joints such as OEM/honda
Old 06-22-2015
mapdog's Avatar
What point are you trying to make? I get it from about the second reply. I walked into Advance and asked for ball joints. I got screwed on the deal and there is no need to rub it in.
Old 06-22-2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Is it possible that the rubber was damaged during installation? or was excessive grease put in?
Old 06-22-2015
CIV1C's Avatar
CIV1C will become famous soon enough
Look on the bright side. If you did the work yourself you just wasted your time. You can get free ones, take those and sell them on craigslist. Buy moog ones. You'll lose maximum $40 plus your time if you can't sell the free ones on Craigslist. You'd have to buy the moog ones anyway. Anything you sell the free ones for is a bonus
Old 06-22-2015
Stock 99's Avatar
^ wow way to make lemonade.
your a glass half full personality aren't you?
Old 06-22-2015
Damn, I was making the popcorn and I missed all the action!
Old 06-23-2015
mapdog's Avatar
I think more than likely, it was just the cheepo ball joints I bought from Advance. I was fooled by their "lifetime warranty." I'll get the Moogs soon and lick my wounds.
Old 06-23-2015
zjeproks's Avatar
zjeproks is an unknown quantity at this point
Return the Driveworks at Advance Auto for warranty but ask for store credit instead. Order the Moog from Amazon for $27.39 each.
Old 06-23-2015
Prelude Owner
GolNat's Avatar
^ sounds like a good plan to me!
Old 06-23-2015
mikey1's Avatar
Old 06-24-2015
mapdog's Avatar
Okay, so I got burned by Advance and most have correctly pointed out that it'll only cost me my time.
So here's my question:
Moog -- I've been told they have a thick boot and will last
TRW -- Also available from a few sources. Looks good; I trust the name and they appear to more like the OEM Honda (no zerk fitting).
Honda OEM -- Not sure who makes these, they are missing from the schematic on most Honda parts websites (under knuckle)
Which would you choose?
Old 06-24-2015
mikey1's Avatar
how long did the original ball joints last?
Old 06-24-2015
mapdog's Avatar
I think I know where you're going with that. Well over 200k miles.
Old 06-24-2015
mikey1's Avatar
seems like an easy decision to me.....but its your dime
Old 06-24-2015
mapdog's Avatar
My worry is the OEM civic ball joint was pressed in without any C clip. The aftermarket ones come with a C clip. I don't know if the press in/press out process is causing any looseness that will eventually lead to separation.
Old 06-24-2015
mikey1's Avatar
you need to test the size of the opening before installing a new ball joint, if the opening is too big then you need to replace the entire knuckle
read the attached bulletin.......
Old 06-24-2015
mikey1's Avatar
you dont wanna end up like this guy......
https://www.civicforums.com/forums/4...er-assmnt.html
Old 06-24-2015
mapdog's Avatar
Awesome info. Thank you. I wondered if it could ever slip.
Quick Reply: 2002 Civic Ball Joints again
