Help: my check engine light will not come on at all.
Rep Power: 0 Help: my check engine light will not come on at all.
I bought a 2001 civic lx and i noticed that the check engine light will not turn on when i twist the key to turn on the car. I have the fuses but they're all good and idk what the problem could be help please...
Re: Help: my check engine light will not come on at all.
See what fault codes are in it....I'd expect something expen$ive like a catalytic converter or a transmission.
I would immediately assume someone disabled the check engine light so you would buy the car, not knowing right away it has problems. One would need to take some time to take it apart, diagnose and prove it though.
You might read this thread too, this guy just bought a Hybrid and the sellers cut out the check engine light and IMA warning lights
Rep Power: 0 Re: Help: my check engine light will not come on at all.
you dont need a new cluster, you just need to repair the problem with the light
Received 1,143 Likes
Rep Power: 485 Re: Help: my check engine light will not come on at all.
No idea why "check the bulb" wasn't the first piece of advice. It's a small incandescent bulb with a twist base. Pull the cluster and check the bulbs. It should be pretty straightforward to tell if the bulb is burnt out or not.
JackImpact
01-12-2012 09:49 PM
aroyale15
11-18-2010 01:57 PM
Jeff
06-11-2006 09:23 PM
