2005 air conditioning fading
Old Jun 8, 2014
Hutchoo's Avatar
Hutchoo is an unknown quantity at this point
My a.c. only works for a few minutes when I first start up. It sounds like the compressor kicks in as does the fan on the radiator. After a couple of minutes the cold air fades. It has always worked but it looks like it needs some attention for this season. Fuses are good. 204,000 k. Any tips?
Old Jun 8, 2014
Re: 2005 air conditioning fading
Does the compressor continue to run after it gets warm?
Do the fans continue to run after it gets warm?
Old Jun 8, 2014
Hutchoo's Avatar
OK I drove it from 8-8:20 pm and A.C. was freezin'.. evening temperature outside had dropped to 21C. Then I stopped and left it running. The A.C. went from freezing to normal (21C). I had someone turn the inside button on the dash on/off several times and the fan came on/off but I don't think the compressor kicked in. There was no noticeable change in engine sound/strain, just the fan turning on/off. WEIRD...
Old Jun 8, 2014
Assuming the radiator fans are still running but the compressor clutch quit engaging......Next step would be to verify whether or not the compressor clutch is still receiving power (B+) when the compressor quits.
After it quits: Tap on clutch relay. Does the compressor engage immediately?
Old Jun 8, 2014
Hutchoo's Avatar
Where is that? I'm guessing it is the uppermost unit with the hoses attached to it...
Old Jun 8, 2014
Where is what?
Old Jun 8, 2014
Hutchoo's Avatar
clutch relay? back at it in the daylight tomorrow...
Old Jun 8, 2014
In the engine compartment fuse box.
Relay for compressor clutch is #D
Old Jun 8, 2014
Hutchoo's Avatar
oh ya, thanks.
Old Jun 10, 2014
Hutchoo's Avatar
I think the compressor is shot, they say the part is not covered by warranty unless I put a drier in too. Any thoughts?
Old Jun 10, 2014
What makes you say this?
Earlier you stated:
Your problem is not the compressor. It works.
If it needs a clutch or a coil, you can buy the individual pieces through Honda.
I'd much rather keep a working original compressor than install any aftermarket reman (that will probably only last one year).
Old Jun 10, 2014
Hutchoo's Avatar
Maybe needs a clutch? I can turn it by hand.
Old Jun 10, 2014
Remember, I stated this:
I assume you haven't done this.
This stuff is easy to figure out if you have a little time, a few tools, and a little knowledge of how it works.
Diagnosing can help you avoid pissing money away on wildass guesses.
Old Jun 10, 2014
Hutchoo's Avatar
Yes,I agree. It was fine today and blew cold, so cold tonight I had to switch it off. I will resume diagnosis tomorrow. The friendly neighbourhood mechanic says the only solution is to put a whole new compressor, drier etc to the tune of $700+.... Hard for me to justify that after it worked fine today!
Old Jun 10, 2014
I'd be friendly too if I could get that sort of cash for wildass guessing.
I don't get my money from guessing.
Guessing doesn't net consistent good results.
It works great when it works, so....
It's not the compressor (not the mechanical, pumping part of it anyway).
It's not low on freon.
You need to figure out why the compressor quits operating, and it's simple electrical diagnosis at this point. Just gotta do the testing WHILE it's quit.
Old Jun 20, 2014
Hutchoo's Avatar
OK back at it. It is working most of the time. When it quits after running a while, the clutch does not engage. It resumes if I tap it. The cabin filters were clogged so I replaced them if that matters. Power is there.
Old Jun 20, 2014
Tap what?
Old Jun 20, 2014
39794-SDA-A05 is the part number for the updated/improved relay.
MITSUBA is the brand name on the improved part.
Old Jun 20, 2014
Hutchoo's Avatar
Clutch
Old Jun 20, 2014
You tapped on the clutch itself and it started working again?
Check clearance between the clutch plate and the pulley.
Spec is 0.50mm +/- 0.15mm
Check resistance of the coil too. Spec says
3.05-3.35 ohms
Old Jun 20, 2014
Hutchoo's Avatar
yup. I'll check clearance tomorrow in daylight.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
amrhamed
Aug 31, 2015 07:47 PM
MajTom
Jun 2, 2015 11:48 AM
davidarenberg
May 16, 2015 08:45 AM
